Car Died, Please Help
Well the Trans Am is dead once again, heres what I did. I disconnected the drivers side oxygen sensor to do something else to the car, put the car back down, but i forgot to reconnect the oxygen sensor. Started car and car ran fine, took for drive around block, and went wide open throttle with oxygen sensor disconnected, car died at corner, and now it won't start. It is a 1994 Pontiac Trans Am. Need help asap!
Rob, before reading your reply, I went out and bought a new coil because that has been the problem every other time my car wouldn't start. That didn't work, and I took a look at the fuses and the ignition fuse was blown. I wish I would have read your reply before I bought the coil, thanks for the heads up, your info is always appreciated!
