Car keeps blowing fuses
Today I scanned my car and found that the Air Pump fuse had blown, I found a 40amp where there should have been a 20, I replaced it with a 20amp and it blew, tried another one, it blew, then tried a 30amp it also blew. What could be causing this? 95 z28. Thanks.
Your air pump is most likely shot. They trap moisture and eventually corrode from the inside.
Carefully unplug the connector at the air pump and see if it still blows the fuse. If is does, you have a short somewhere in the wiring to the air pump. If it doesn't, the air pump itself is most likely shot. Remove it, disassemble, and you'll see.
Mine finally died last year, on my '94 with 170k miles.
I ran into the same problem. I did what was suggested above and removed the pump and took it apart and voila, moisture built up and killed the pump. Just for giggles, check your MAF screen for any debris that might have come out of the pump. Mine was coated with some spongelike stuff that was on the inside of the pump.
fpete1992
Dec 11, 2014 03:51 PM
