Autocross and Road Racing Technique There is more to life than a straight line
Nitto 315/35 17" 555RII's delayed
Old Dec 7, 2003 | 10:32 PM
Buttercup's Avatar
Unhappy Nitto 315/35 17" 555RII's delayed
I'm sure I'm not the only one here that's been in the market for these tires so I thought I'd share.
In a reply from my inquiry to Discount Tire Direct.
Thank you for your inquiry.
The Nitto 555R II production has been delayed in the 315/35-17
size. At this point, the tire may not be available until Spring
2004. The pricing should be close to the Drag Radial in that
size.
Old Dec 7, 2003 | 10:42 PM
94bird's Avatar
Well, if that's true, that's too bad. I was planning on buying a set to use as practice tires. In reality though I doubt I would have gotten them before spring, so as long as they come out then it won't affect me much. Heck, my car's in hibernation until April.
Old Dec 7, 2003 | 10:54 PM
Buttercup's Avatar
I certainly wouldn't be driving on these tires here in Wisconsin right now either I'm just a little worried now that it'll be late spring when they are introduced, they'll be backordered, gotte get them installed, yada, yada.
I'd be more comfortable if I could take care of it before spring arrives. Even if I am normally a procrastinator
My current tires are long overdue for replacement
Old Dec 8, 2003 | 09:38 AM
chuck's Avatar
That is disappointing. Last I heard they would be available in October '03.
I have been using four 315/35/17 Nitto drag radials with pretty good results (they are better than 275 RII's).
Old Dec 19, 2003 | 11:29 PM
Steve in Seattle's Avatar
I'll get a set for my ZR1's in the spring I guess... just as well, I started a 383 build up and can use tire funds for a rear end.
RUENUF
Mar 13, 2016 03:37 PM
HibachiZ28
Nov 6, 2015 12:53 AM
autoxr166
Sep 25, 2015 04:21 PM
mrwz28
Jul 8, 2015 09:11 PM
