wheel spacers...
wheel spacers...
Im ordering 4 17x11 50mm offset wheels so they tuck up as much as possible and I know up front if you trim the plastic cover and use a 1/8" spacer or trim the spindle they will fit, in the rear my car is clearanced for 9.5" wide wheels with 285's and a 65mm offset with a 1" drop, do you think I will need a spacer with the 50mm offset if im clearanced that much already and if so would the the suggested 1/4" spacer damage studs, I'm not really going to be drag racing? Also where the hay do you get wheels spacers?? Thanks!
I highly suggest you replace your studs with ARP's. For cheap spacers, go here:
http://www.cmwraceparts.com/Wheels/w...heel%20Spacers
$9.00 each. They aren't hubcentric (but I don't believe that matters on our cars with 1/4" thickness). They aren't cast and fit nicely over the studs to stay centered. Here's a pic:
http://www.cmwraceparts.com/images/dixon/wlspacer.jpg
Trey, I keep them on the rear of mine, no sense taking them off.
SPACERS
1/4" TO 3/4" THICK HUB CENTRIC FLAT SPACERS $40 EACH.
THANKS FRED GOEKSE
Fred Goeske
Design Deluxe
21300 Deering court
Canoga Park, CA 91304
Voice (818)992-5700
Fax (818)992-0325
www.wheeladapter.com
SPACERS
THANKS FRED GOEKSE
Fred Goeske
Design Deluxe
21300 Deering court
Voice (818)992-5700
Fax (818)992-0325
So whats hubcentric and is it nessicary, I like the 8 buck a piece ones better for price if they are ok to use... and in the front I heard to use an 1/8 spacer but would it be ok if I just trimmed back the spindle? Also like if my fenders are clearanced like I said in the original post would I need a spacer with teh 50mm offset 11 inchers with a 1.5" drop (only dropped 1" now but planning on 1.5") Thanks for all the help!
Hub-centric simply means it will fit perfectly over the raised circular area on the hub. It's just a more precise fit. The spacers I got are billet aluminum and basically weigh nothing.
Make sure the spacer you get is not a universal spacer, you don't want one that has the possiblity of moving around.
You MIGHT get away with trimming the spindle. I might try that on mine to see but it might be January before I can do it.
I have a Trans AM with G2 springs ....
The trimming needed is basically a little "bump" on the knuckle face. Ironically, it aligns perfectly with a the lip of a 17" wheel.
With a Prospeed brake kit up front, a 3/16" spacer is needed between the rotor and the hub for clearance purposes. But the 11" ZR1 50mm offset rims clear the calipers w/o a problem, so no wheel spacer is required. However, running a WS6 rim does require an additional 1/8" spacer so the spokes don't hit the caliper. I do get some rub on the plastic inner fender while turning. NBD, though
I run a 50mm offset 11" rim in the rear and I had to clearance the inner fender to keep them from rubbing. I also rolled the lip for insurance.
I believe that is correct. And to clarify, a 4" right angle grinder made short work of it and I ground it smooth, flush with the surface.
However, I'm not 100% sure as I have that spacer between my rotor and hub so the rotor doesn't hit the lower A-Arm.
If you can wait, tonight I will measure the distance between the 50mm rim and the knuckle (bump removed) with the spacers I have.
With a 3/16" spacer (needed to space the PSM rotor away from the lower A-Arm) and using an AFS ZR1 replica wheel with a 50mm offset, I see about 1/2" of clearance between the wheel lip and the face of the knuckle.
If you deduct out the 3/16" spacer, there is still 5/16" clearance AFTER the bump is ground off.
These measurements were taken with the a tape measure while standing on my head, suspension at full droop and no swaybar. The car is on jackstands awaiting some much needed TLC.
HTH
BTW ... I live SW of Ft. Worth near Motorsports Ranch in Cresson
HTH
Besides for the price of ARP studs ($15 a pack of 5), it's not worth NOT doing it if you autox or track your car, regardless of spacer type or even no spacer at all.
man i wish i was still in machining school. id make my own instead of paying forty bucks. oh well.
so would it help to go with a small spacer. i know it would make my stance wider, but would such a small increase help enough to justify the $200 cost? Trey
