lt4 396 cylinder wear
I have a freshly rebiult 396 (4.040" bore x 3.875" stroke) with about a 1,000 miles on it. I had a leaky head gasket so I pulled the head. My engine is already starting to show wear in the cylinder bores. The cross-hatching (sp?) has worn away in about a 3/4" wide strip on the upper and lower portion of the bore...from side loading? The pistons are new custom slugs from Diamond and I run a 6" rod. Seems like I should not be seeing this much wear yet so soon. I'm running dyno oil as I'm still breaking it in 5w30. Has anyone else had this experience? Any thoughts appreciated...
sleeperZ96BT
Sep 9, 2015 08:28 AM
Aug 7, 2015 08:52 AM
Jul 17, 2015 02:47 PM
NewsBot
Jul 8, 2015 06:47 PM
