Anyone have to or tried shimming slave cylinder?
Old Oct 8, 2003 | 09:34 AM
Kreinmc's Avatar
When i installed my new master and slave I had to tighten the slave atleast 3/4" to get it to fit flush. So the rod must have pushed the fork atleast that amount and it is probably held at that spot when driving. 97bowtie says his fits flush and he did not need to pull the slave on with the bolts. The clutch doesn't grab very hard and seems to slip a little bit when taking off. I don't see how i would go about adjusting this though.
Old Oct 8, 2003 | 10:47 AM
NVetro's Avatar
I have done this, its supposed to work. But it did not work for me.
Old Oct 8, 2003 | 04:07 PM
97bowtie's Avatar
The slave shouldn't need to be pulled on w/the bolts. It should fit flush w/out being forced on.
Old Oct 8, 2003 | 04:13 PM
xxsaint69x's Avatar
uhh no....u need to push the rod in and put it in (as soon as u let go of the rod it will start expending, so u have to pull it in with the nuts or push it it with one hand and tighten the nuts. If your rod doesnt extand by itself then there is something wrong with your slave or master.
Marcin
Old Oct 8, 2003 | 04:27 PM
viperkiller's Avatar
you have a problem. i had that problem with a 97z we ended up taking all the stuff back went to gm and bought the whole unit (gm sells slave master line, and bled with fluid in it) fixed the problem.
Old Oct 8, 2003 | 05:17 PM
97bowtie's Avatar
I just went a checked and Marcin is right. My memory failed me. You do have to compress the slave rod to install it - that or pull it on w/the nuts.
Old Oct 8, 2003 | 05:50 PM
xxsaint69x's Avatar
btw, what clutch did u go with... I just put a STreet Twin in my car and i LOVE IT
Marcin
Old Oct 8, 2003 | 05:56 PM
97bowtie's Avatar
He put a Mcleod single disc w/a SLP pressure plate. He's at work so i'm answering for him.
Old Oct 8, 2003 | 06:07 PM
rlax31's Avatar
Marcin
This is correct, to install it correctly, you have to push in the slave and stick it on there and hold it while you get the bolts on
G-BODYT56
Jan 14, 2022 11:14 PM
94Maroz28
Oct 27, 2015 04:38 PM
jayblev95
Sep 26, 2015 09:44 PM
Rod Bender
25
Sep 16, 2015 01:47 PM
jackpawt883
Sep 10, 2015 08:53 PM
