Anyone have to or tried shimming slave cylinder?
When i installed my new master and slave I had to tighten the slave atleast 3/4" to get it to fit flush. So the rod must have pushed the fork atleast that amount and it is probably held at that spot when driving. 97bowtie says his fits flush and he did not need to pull the slave on with the bolts. The clutch doesn't grab very hard and seems to slip a little bit when taking off. I don't see how i would go about adjusting this though.
Originally posted by 97bowtie
The slave shouldn't need to be pulled on w/the bolts. It should fit flush w/out being forced on.
Marcin
Originally posted by xxsaint69x
uhh no....u need to push the rod in and put it in (as soon as u let go of the rod it will start expending, so u have to pull it in with the nuts or push it it with one hand and tighten the nuts. If your rod doesnt extand by itself then there is something wrong with your slave or master.
Marcin
Marcin
jackpawt883
Sep 10, 2015 08:53 PM
