new 1/8th mile times
Old Aug 9, 2003 | 12:21 AM
worak's Avatar
here they are
1st run
rt- .571
60ft- .2.299
1/8th 8.922 @ 87.51 mph
2nd run
rt- .483
60ft- 2.524
1/8th 9.598 @ 85.87 mph
3rd run
rt- .736
60ft- 2.296
1/8th 8.850 @ 88.25 mph
4th run
rt- .591
60ft- 2.329
1/8th 8.92 @ 88.25 mph
5th run
rt- 1.403
60ft- 2.256
1/8th 8.823 @ 89.09 mph
i know my 60 has to come down, but it still drives the crazy to see a car go 84 mph and run 8.4 in the 1/8th mile. with my trap speeds anyone think im in the 7's, if i can hook up?
Old Aug 9, 2003 | 12:30 AM
AsianSensation's Avatar
Thumbs up
Time for some DRs.
Old Aug 9, 2003 | 08:55 AM
RealQuick's Avatar
NIce mph. What are the specs on the cam?
Old Aug 9, 2003 | 09:06 AM
TN94Z's Avatar
Not trying to steal your thread or anything, but my car runs 8.81 in the 1/8, akmost exactly what you are running....granted I am spinning too..but my mph is only like 79. I have a 1.9 60ft but it is just losing it down the track somewhere. I mean my 2000 silverado runs 76 mph. Is my car trying to tell me that I need a cam and some headwork or what???? I figured if my mph was higher(around 87 or 88) then I would have much better et's. Any suggestions??
Old Aug 9, 2003 | 09:44 AM
frmula1's Avatar
From: Somewhere between a shotgun barrel, and a blood spatter on the wall.
your mph are HIGH!
before my drivetrain mods i did a 9.1 in the 1/8 with a 2.3 60' and my highest mph was 77.xx
i wonder whats up with that
Old Aug 9, 2003 | 10:10 AM
LT1ponykilla's Avatar
Good mph man! With it being that high and if you had some dr's. You could easily be running 8.0's - 8.2's.
Old Aug 9, 2003 | 01:08 PM
brain's Avatar
Nice traps, but it also helps to find out what the other cars in the area run trap speed wise at that track. With your mods, the trap looks to be where I'd expect, and a 2.2 60' can definitely kill e.t. However, what I have come to expect from a H/C LT1 isn't what most people get. Did you run the car at the same track before the h/c swap? If so, and it was running around 80 - 83, then I'd say you picked up some good power, but just need to learn to drive . Or get some good tires. With a 2.0 60' I was running 8.8s @ 81. If you can get that 60' down to even a 2.0, you should see at least an 8.4.
On another note - important lesson learned here - Lookie
His 2nd run was a 9.5 @ 85mph with a 2.5 60'. Now some people here won't believe his next times, because THEY know the formula lower 60' = lower e.t. = lower mph.
So was he lying on the 8.82 @ 89 with a 2.2 60'? Unbelieveable, he lowered his 60' by .3, lowered the e.t. by .7, but WAIT, INCREASED the mph by 3, and that is only in the 1/8th!
Learn any lessons yet?
Its called traction, and when not spinning, its getting the car to a faster speed sooner, which means less distance too.
Old Aug 9, 2003 | 09:42 PM
worak's Avatar
the cam is a 224/230 on 112
Old Aug 9, 2003 | 10:27 PM
worak's Avatar
im trying to remember what other cars were running. lets see there was a lt1 trans am there running 8.7 @ 83 mph, older fbody 88 or so, 8.4 @ 84 mph. a bunch of mustangs running 9.5 @ 78 mph. i raced a 97 cobra he went 9.071 @ 82.55 mph with a 2.18 sixty. the track has no grip at all. my trap speeds were among the highest besides the big dogs running 5's at like 150. its a test and tune night where as long as it has wheels you can run it, so they wont prep the track because of all the idiots on 4 wheelers and crap.
Old Aug 9, 2003 | 10:46 PM
FastZinTennessee's Avatar
I'm running 8.1s @87 mph..... Traction is your friend.
John
Old Aug 10, 2003 | 11:16 AM
snakeatinZ's Avatar
The best time I could get out of my car was a 8.32, and my mph was 89.6, I could get it off the line easy, but 15 feet down the track It would go up in smoke??? I could not get traction what so ever That was with et streets too. Just horrible track prep!! I know I could have got in to the 7's, and I belive you could have too!!
F'n1996Z28SS
Aug 23, 2023 11:19 PM
jb4xx
Feb 2, 2015 10:00 PM
jayblev95
Track Kill Stories
Jan 15, 2015 07:48 AM
centric
Aug 15, 2002 09:04 PM
