In the middle of clutch install! torque spec?
Installing a SPEC stage 3 ceramic 6 puck....what do i need to torque the bolts in the clutch to? Already torqued the flywheel bolts....just need the clutch bolt specs now.
Thanx
Joe
Thanx
Joe
TORQUE SPECS
The torque are as follows: flex plate 22 ft lbs., flywheel 74 ft lbs.,
flywheel housing bolts 35 ft lbs., trans brace bolt/screw37 ft lbs.,
trans brace nut 37ft lbs., trans bolt screw26 ft lbs.
stockssn2o
May 25, 2015 08:54 AM
