OVC wires to fit the Made-For-You looms?
I was wondering what other wires are out there that will fit an OVC wire kit. I think thunderracing just gave me the SBC universal wire kit plus opti terminals for the lt1. Does accel or anyone make a universal wire kit with long wires?
Re: OVC wires to fit the Made-For-You looms?
It just takes a little time to get them assembled.
I'm using MSD part # 32139 Call summit and tell them what you're doing and they can double check the #. It's a pain to work out the routing and lengths the first time, but after you have it set replacing them is easy.
I'm also using the MFY OVC looms on my 97. I had to make some pretty exstensive changes to work around my emissions equipment. Just giving you a heads up.
I am using MSDs with the made for you looms. they are only meant for 7mm-8mm so i had to drill out the looms a little b.c they were pinching my wires. if i remember right, i got a universal kit and some opti boots from jegs. i think i ordered both seperate but its been a while so im not real sure. hope that helps. i also have pics of them in my sig if you wanna see how they look.
danielbmx
Aug 27, 2002 11:11 PM
Wilson
Jul 21, 2002 05:08 PM
