OVC wires to fit the Made-For-You looms?
Old May 9, 2003 | 10:59 PM
Rodrigues's Avatar
I was wondering what other wires are out there that will fit an OVC wire kit. I think thunderracing just gave me the SBC universal wire kit plus opti terminals for the lt1. Does accel or anyone make a universal wire kit with long wires?
Old May 9, 2003 | 11:09 PM
Buttercup's Avatar
The only thing specific to the LT1 is the opti boots. I run MSD superconductors fwiw.
Old May 9, 2003 | 11:19 PM
Rodrigues's Avatar
Your running MSD wires over the valve cover? Whats the part # of the wires you used? Summit has pages of MSD wires...
Old May 9, 2003 | 11:31 PM
Buttercup's Avatar
Try MSD p/n 32129
Old May 9, 2003 | 11:35 PM
Shawn 97 Z28 M6's Avatar
Texas Moderator (1998-2009)
I run taylors w/ my ovc wires...
Old May 10, 2003 | 11:27 AM
t-trimz28's Avatar
Re: OVC wires to fit the Made-For-You looms?
What's wrong with the Taylor wires? If you already have them, why spend extra on another set.
It just takes a little time to get them assembled.
Old May 10, 2003 | 06:12 PM
Ryan 97 Ram Air T/A's Avatar
I'm using MSD part # 32139 Call summit and tell them what you're doing and they can double check the #. It's a pain to work out the routing and lengths the first time, but after you have it set replacing them is easy.
I'm also using the MFY OVC looms on my 97. I had to make some pretty exstensive changes to work around my emissions equipment. Just giving you a heads up.
Old May 10, 2003 | 07:45 PM
turbo_Z's Avatar
I am using MSDs with the made for you looms. they are only meant for 7mm-8mm so i had to drill out the looms a little b.c they were pinching my wires. if i remember right, i got a universal kit and some opti boots from jegs. i think i ordered both seperate but its been a while so im not real sure. hope that helps. i also have pics of them in my sig if you wanna see how they look.
Old May 11, 2003 | 03:37 AM
Rodrigues's Avatar
I got taylors installed but they are arcing...
Old May 11, 2003 | 11:57 PM
blksunshine's Avatar
yeah my taylors did the same thing, I am going to msd's as well
linz
3rd Gen / L98 Engine Tech
Oct 22, 2015 07:59 AM
GigaMp3z
Feb 20, 2003 02:57 PM
danielbmx
Aug 27, 2002 11:11 PM
Wilson
Jul 21, 2002 05:08 PM
Wilson
Jul 21, 2002 04:58 PM
