1 wheel peel cause? Low gear oil possibly?
Old May 9, 2003 | 09:59 AM
DarkHorse's Avatar
Posted a few days ago about a possible 1 wheel peel problem that I may be having. I crawled under the car and noticed that the rearend is leaking fluid pretty good out of the front pinion yoke. Could low fluid possibly cause the diff to work incorrectly? I'm sure it could but would filling it back up help regain 2 wheel traction? Thnks
Old May 9, 2003 | 10:08 AM
Low fluid could have caused the posi to go out, but I doubt adding fluid is going to repair it.
Old May 9, 2003 | 10:10 AM
Mizz96Z28's Avatar
If you pulled a one legger for awhile your posi is probably shot. Adding fluid is a good idea but won't bring back the 2 wheel hole shots. It'll probably stay a one wheeler till you replace the differential unit.
DarkHorse's Avatar
Shoebox, you got any write-ups on replacing the diff with one from an LS1 car? or SLP take-off? What about the front seal replacement? Thanks
Old May 9, 2003 | 10:20 AM
Nope and nope. A search will probably net you some info.
I do know that on the rear end swap that you cannot mix axle shafts and brakes.
Old May 9, 2003 | 10:31 AM
DarkHorse's Avatar
Cool, well not really but...., I'm currently looking for a complete rear outta a 98 up LS1 car. Isn't there an F-bod junkyard out there somewhere? I remember seeing a link for it some time ago.
Old May 9, 2003 | 10:50 AM
94-3.4's Avatar
www.tacreationsusa. com
www.speedautomotive.com
http://www.fastblackcar.com/camaro/lsd.htm
That link might be able to help you with the install. Should be about the same procedure.
ChrisFrez
Nov 30, 2014 08:41 AM
Jul 4, 2005 05:00 PM
redz_02
Jul 24, 2002 09:42 AM
Darth Xed
13
Jul 22, 2002 12:45 PM
