? for those running LT4 hot cam on stock heads??
? for those running LT4 hot cam w/ stock heads??
your 1/4 mile times is what I really want to know,
I don't have the PCM tuned yet, so I know that is really hurting me, but here is my best so far:
Temp: 79*
Relative Humidity: 100
Barometer: 30.49
RT: .764
60'2.102
330: 5.867
1/8: 8.818@83.03
1000:11.408
13.530@106.19
Does that look right, given the 60' time and running on the stock PCM program?? I am really curious. people that have similar mods or less are running way better than I am cutting similar 60' times, but the MPH are less than mine...
Let me add this run was made on 275/40 nitto DR's in the back and 275/40 BFG comp/ta in the front...all mounted on ZR1 rims, if that makes any differance..
Temp: 79*
Barometer: 30.49
RT: .764
60'2.102
330: 5.867
1/8: 8.818@83.03
1000:11.408
13.530@106.19
I was running 13.0 consistently and a couple 12.9's but that was with 4:10's, that was before the cam/rr's & wp for what it's worth. I'm running it again soon and I am fairly certain it will be in the mid 12's now based on the way the car feels since the cam, feels much stronger overall now and pulls much harder. I did have the PCM tuned for the cam though, other mods in sig.
Originally posted by magius231
well the humidity isn't helping a whole lot. I would expect with those mods you should be easily in the 12's. BTW learn to launch it...2.1 60' on DR's is not so good
Originally posted by 1997rblckSS
Ok let me get this right, you ran 13.0's consistantly with just 4.10's?? no other mods? the rest of the motor stock? before the LT4 cam install?? son of B@tch I can't drive worth a ****...
No, I'm sorry, I meant with all my bolt on MODS but before the cam/rr/wp. I just meant I had similar bolt ons to you but I did have 4:10's. With all the bolt on's and stock gears I was running 13.2x's. I think you may need to have the PCM programmed and maybe your rockers are not adjusted properly. Although this cam and others do really like the 4:10's
