? for those running LT4 hot cam on stock heads??
Old May 8, 2003 | 02:37 PM
1997rblckSS's Avatar
? for those running LT4 hot cam w/ stock heads??
your 1/4 mile times is what I really want to know,
I don't have the PCM tuned yet, so I know that is really hurting me, but here is my best so far:
Temp: 79*
Relative Humidity: 100
Barometer: 30.49
RT: .764
60'2.102
330: 5.867
1/8: 8.818@83.03
1000:11.408
13.530@106.19
Does that look right, given the 60' time and running on the stock PCM program?? I am really curious. people that have similar mods or less are running way better than I am cutting similar 60' times, but the MPH are less than mine...
Let me add this run was made on 275/40 nitto DR's in the back and 275/40 BFG comp/ta in the front...all mounted on ZR1 rims, if that makes any differance..
Old May 8, 2003 | 03:18 PM
GREGG 97Z's Avatar
I was running 13.0 consistently and a couple 12.9's but that was with 4:10's, that was before the cam/rr's & wp for what it's worth. I'm running it again soon and I am fairly certain it will be in the mid 12's now based on the way the car feels since the cam, feels much stronger overall now and pulls much harder. I did have the PCM tuned for the cam though, other mods in sig.
Old May 8, 2003 | 03:29 PM
Ok let me get this right, you ran 13.0's consistantly with just 4.10's?? no other mods? the rest of the motor stock? before the LT4 cam install?? son of B@tch I can't drive worth a ****...
Old May 8, 2003 | 03:31 PM
magius231's Avatar
well the humidity isn't helping a whole lot. I would expect with those mods you should be easily in the 12's. BTW learn to launch it...2.1 60' on DR's is not so good
Old May 8, 2003 | 03:33 PM
if I had a dime for everytime someone told me that...
Old May 8, 2003 | 03:55 PM
GREGG 97Z's Avatar
No, I'm sorry, I meant with all my bolt on MODS but before the cam/rr/wp. I just meant I had similar bolt ons to you but I did have 4:10's. With all the bolt on's and stock gears I was running 13.2x's. I think you may need to have the PCM programmed and maybe your rockers are not adjusted properly. Although this cam and others do really like the 4:10's
Old May 8, 2003 | 04:14 PM
Yeah, the car is screaming 4.10's, I am scheming this winter to do a moser 12 bolt swap with eaton posi, 4.10 gears, and 33 spline axles and 1350 yoke, pretty much the samething a member of the car club I am part of has.....I have adjusted the RR's accordingly, I get a little clickity clack, but nothing annoying...kinda frustrating because before the cam and LT's I was running 13.8's @ 100mph with a 2.0 60' on street tires...so you can probably see my frustration only able to gain .3 of a second...the car club I am part of MTFBA has a dyno session coming up, probably get the tuning done then...believe it or not my first trip to the track this year I ran a 14.2@103 and wow I was pretty upset about that, I changed the plugs out to NGKt55r's and did a TB bypass and ran the 13.5 a few weeks later...so I feel I am heading in the right direction just need some better WOT tuning..
djangoroar
Parts Wanted
Feb 21, 2015 11:47 PM
Killer94z
Jan 13, 2015 12:06 PM
birdblack
Dec 30, 2014 06:59 PM
Queens94z28
Nov 20, 2014 06:03 PM
GigaMp3z
Feb 20, 2003 02:57 PM
