Brake line questions
Old May 8, 2003 | 12:06 PM
danner's Avatar
I plan to install a braided brake line kit on my vehicle. I have seen kits from earls, russel and from tire rack.com. Can anyone recommend a particlar kit or are thay all basically the same. I have just installed new rotors and pads. The install looks preety staight forward, my concern is - when i disconnent the line from the rotor is there anything special that needs to be accomplised other than bleeding each rotor and not to run the container dry?
Old May 8, 2003 | 04:40 PM
danner's Avatar
TTT for the evening folks, really could use some info, what to look for etc. discs ao all four and again new pads and rotors
Old May 8, 2003 | 08:49 PM
Bud M's Avatar
I believe the braided lines at Tire Rack are made by Goodridge. Both Earl's and Goodridge are quality products. The install is not difficult. New crush washers should be installed with new brake lines. Bleed your brakes after installing new lines, starting with the wheel furthest from the master cylinder and working to the wheel closest to it. If you plan to ever upgrade to LS1 brakes, you should get a set for 98 or later. And get a big bottle of brake fluid.
Old May 9, 2003 | 07:32 AM
danner's Avatar
Thanks Bud M, good info. I think I will go with the earls hyperfirm kit. I am hoping the crush washers com with the kit. One last question If I keep the fluid full while bleeding - is the abs unit a concern-Should I bleed that as well? Thanks again
Old May 9, 2003 | 04:32 PM
Mtrhds94Z's Avatar
If I recall Earl's is a 5 line kit, Russell's is a 4 line kit..
Earl's came with the washers..
Only other thing I recall was the fifth line[on the rear gear housing] was hard to get the old one OFF.. almost ruined it!Soak em good with PB Blawster..
Old May 9, 2003 | 04:36 PM
danner's Avatar
Thanks, The PB Blaster worked wonders on my bolts when i did my header install. that stuff is like gold
Old May 9, 2003 | 06:29 PM
gstaehle's Avatar
I put the Earl's on my 96Z. It has five hoses and all necessary hardware. It made a noticable difference in the break feel (firmer). The first time I blead only the wheel cylinders and had a very low pedal. The book recomends bleeding the ABS hydraulic modulator first. First the Rear ABS Bleeder then the Front ABS Bleeder (This is called Priming the ABS hydraulic modulator). After this go to the furthest wheel, Right Rear, Left Rear, Right Front then Left Front. After that I had no problems.
Old May 9, 2003 | 09:56 PM
Compstall's Avatar
Sometimes even break free won't help on a frozen brake line. Make sure you use B-nut wrenches on the lines or you can easily round off the nuts.
I also used the Earl's kit. They do come with crush washers.
I have a complete write-up on my experience on my Cardomain webpage in my sig. I ended up replacing an entire brake line because i couldn't get a b-nut loose with ANYTHING and ended up cutting it off. Yet another day job turned into an entire weekend.
- Brent
Old May 10, 2003 | 06:37 AM
danner's Avatar
- Brent [/B][/QUOTE]
I can relate to that, I will be extra careful and thanks for the info.
Jazsun
Dec 29, 2014 12:14 PM
Red97LT1
9
Dec 17, 2014 06:13 PM
Hurin
Dec 13, 2014 07:38 PM
Jul 4, 2005 05:00 PM
