anyone burn plugs wires running uncoated LTs?
thinking about getting some used uncoated longtubes.
anyone have problems burning plug wires or anything?
i did a search but didnt turn up much, except people mentioned brake lines run close.
If u make sure that the wires arent touching the headers, then u should have no problems. Some people use simple ties etc to hold the wires away.
But on a side note, i would think about sending the headers in and getting them coated. Its well worth the money. Before u know it, you'll have the headers installed and will regret not getting them coated when u had the chance
if youre talking about how they look, i could care less, as ill be replacing them eventually anyway.
this is just a temporary setup for about a year.
as for reliability, they will still be good for a year or so right?
I might be able to help you out. I purchased Accel 8.8 300+ race wires, taylor Opti-ends, and a mounting system for over the valve covers. I can't remember the name of the mounting system. It all new. I choose not to use due to my supercharger is in the way and I don't want to remove/replace it.
I'm not sure on how much I'd need. I can't remember how much I paid. Should be 50-75.00
Alex Barnes
Jan 24, 2015 10:21 PM
