anyone burn plugs wires running uncoated LTs?
Old May 7, 2003 | 09:40 PM
got_hp?'s Avatar
thinking about getting some used uncoated longtubes.
anyone have problems burning plug wires or anything?
i did a search but didnt turn up much, except people mentioned brake lines run close.
Old May 7, 2003 | 09:54 PM
chesee48's Avatar
If u make sure that the wires arent touching the headers, then u should have no problems. Some people use simple ties etc to hold the wires away.
But on a side note, i would think about sending the headers in and getting them coated. Its well worth the money. Before u know it, you'll have the headers installed and will regret not getting them coated when u had the chance
Old May 7, 2003 | 09:58 PM
got_hp?'s Avatar
if youre talking about how they look, i could care less, as ill be replacing them eventually anyway.
this is just a temporary setup for about a year.
as for reliability, they will still be good for a year or so right?
Old May 7, 2003 | 10:12 PM
turbo_Z's Avatar
basically if you have at least an inch between the header and the plug wire.. it should be good coated or not coated.
Old May 8, 2003 | 02:28 AM
SVT Killer LV's Avatar
do yourself a favor and do the OVC Looms.. I kept burning wires no matter how good i routed them... OVC Looms and now im all good.. no burned wires...
Old May 8, 2003 | 02:32 AM
texasTA's Avatar
Yep do the OVC wire setup and you will never have to second guess it. The TOTAL kit only costs like 100 and it gives you peace of mind that the job was done right.
Old May 8, 2003 | 11:31 AM
ryker77's Avatar
I might be able to help you out. I purchased Accel 8.8 300+ race wires, taylor Opti-ends, and a mounting system for over the valve covers. I can't remember the name of the mounting system. It all new. I choose not to use due to my supercharger is in the way and I don't want to remove/replace it.
I'm not sure on how much I'd need. I can't remember how much I paid. Should be 50-75.00
Old May 8, 2003 | 11:51 AM
got_hp?'s Avatar
does that mean you have to crimp measure the wires and crimp them yourself?
Old May 9, 2003 | 08:23 AM
ryker77's Avatar
Yes you'd have to crimp the wires. They come with a crimp block. I like the performance of the Accel 8.8 300+ wires over the plain taylor's
Alex Barnes
Jan 24, 2015 10:21 PM
Jazsun
Dec 29, 2014 12:14 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
DubbyZ28Camaro
Aug 4, 2002 12:53 PM
