How can you tell if your car is running lean?
Old May 7, 2003 | 09:34 PM
chasmanz28's Avatar
Question How can you tell if your car is running lean?
i was just curious if theres a way i could tell if my car is running to lean
Old May 7, 2003 | 09:41 PM
kirschman's Avatar
pull the plugs, white(chalky looking) is lean, brown is perfect, and black is rich. Curious, why do u think its lean?
Old May 7, 2003 | 09:50 PM
chasmanz28's Avatar
i was reading a thread about a member saying if you have the hpp3 installed it screws up your car and could make it run lean or too rich, ive had the programm installed in my car for 2 years now dont have a problem but just curious on what he said
Old May 7, 2003 | 10:09 PM
IrocManiac's Avatar
When you melt your pistons you know you're running too lean.
Old May 7, 2003 | 11:13 PM
ATMINF's Avatar
Also if you hear that "pinging" sound under load. Not good.
Old May 7, 2003 | 11:15 PM
chasmanz28's Avatar
pinging means too lean right? and another question if the car is running too rich besides pulling one spark plug to see if its black is there any other way of knowing if its running rich?
Old May 7, 2003 | 11:29 PM
Rodrigues's Avatar
Just pull a plug! Its going to be the best indicator your going to get. Unless there is an exhaust leak or o2 sensor failure your car should be running fine.
Old May 7, 2003 | 11:36 PM
95TA8280's Avatar
Well, the BEST indicator is A/F on a dyno graph.....
Old May 7, 2003 | 11:40 PM
chasmanz28's Avatar
thanks guys for the info, my car is running fine but i will pull a couple of plugs just to see how they are, im sure if i had a problem running bad either way my o2's would be acting up, or getting that ping
Old May 7, 2003 | 11:51 PM
ATMINF's Avatar
Yes, pinging means its running lean.
Old May 7, 2003 | 11:54 PM
turbo_Z's Avatar
your car is likely not running lean. the PCM is set up in a way that makes it almost impossible for you car to go lean unless you add some serious internal mods and heads without programing your computer. or the more common way... add nitrous without adding fuel that can get ugly!
cmdeshon
Dec 27, 2014 10:06 AM
1996LT1Z28
Dec 4, 2014 09:20 PM
nophix
Nov 30, 2014 10:26 PM
USAirman93
Nov 24, 2014 03:37 PM
supercharged94Z28
Feb 24, 2003 10:22 PM
