How can you tell if your car is running lean?
Originally posted by kirschman
pull the plugs, white(chalky looking) is lean, brown is perfect, and black is rich. Curious, why do u think its lean?
Originally posted by ATMINF
Also if you hear that "pinging" sound under load. Not good.
Originally posted by Rodrigues
Just pull a plug! Its going to be the best indicator your going to get. Unless there is an exhaust leak or o2 sensor failure your car should be running fine.
Originally posted by 95TA8280
Well, the BEST indicator is A/F on a dyno graph.....
your car is likely not running lean. the PCM is set up in a way that makes it almost impossible for you car to go lean unless you add some serious internal mods and heads without programing your computer. or the more common way... add nitrous without adding fuel
that can get ugly!
that can get ugly!
1996LT1Z28
Dec 4, 2014 09:20 PM
supercharged94Z28
Feb 24, 2003 10:22 PM
