search function
search function
I know this is a problem on my end but everytime i use the forum search function I d/l a file named search.php should I be D/L anything. .php is also a Walmart Photo Parade slideshow Pic viewer. Any ideas ? So far I have deleted files and cookies with no change.
Re: search function
Try a different browser or different computer and see if you get the same results.
Re: search function
I'm not sure if there is an easier way, but if you right click on a file with that extension that you already have saved to your computer and select open with, Select "Choose Program". (Again, this is with Firefox)
This will bring up a window that has a bunch of programs from which you can choose. Go down and select your browser, then make sure the little box that says, "Always use the selected program to open this kind of file" has a check in it. Then click "OK".
There is probably a much easier way to do this, but i don't know it.
CARiD
Sep 30, 2015 05:44 AM
autoxr166
Sep 25, 2015 04:21 PM
