Site Help and Suggestions For account related issues and questions about how to use this site. Before posting, please search this forum.
Help with search function
Old Mar 2, 2008 | 10:57 PM
Critter's Avatar
Is there section that i haven't found that gives some specifics on the search? Like if i want it to search CC306 Dyno Graphs? From what i have seen it searches each word individually. How can you specify when you want it to search a group of words altogether as you have written it. Is there a section that explains some of this?
Old Mar 11, 2008 | 01:32 PM
Critter's Avatar
ttt?
Old Mar 11, 2008 | 05:19 PM
JasonD's Avatar
Admin Emeritus
It is pretty basic, there isn't much to it. If you want to try an alternate method, hit the main page and use the search engine on the left upper nav which is powered by Google.
Old Mar 11, 2008 | 06:45 PM
Critter's Avatar
cc306 dyno graphs, if i wanted to search just those how would i do it? the search breaks it into 3 seperate words and searches for each single word. how do i search groups?
Old Mar 11, 2008 | 07:23 PM
JasonD's Avatar
Admin Emeritus
In other words, the board search engine doesn't work the way you need it to, but if you follow the instructions above, you might have better luck. Give it a try anyway.
Old Mar 12, 2008 | 12:55 PM
PhantomTA's Avatar
Moderator
actually.. just include the word "and".
cc306 and dyno and graph should do it.
Old Mar 12, 2008 | 01:24 PM
JasonD's Avatar
Admin Emeritus
cc306 dyno graph
"cc306 dyno graph"
All come up with the same results for me. I wish I knew of a trick like that which works well, but it just isn't advanced enough like a search engine like Google. I think it is one of the major downfalls of this software. Hopefully a solution will come into play, but for now that is why we integrated a Google search into the entire site.
Old Mar 12, 2008 | 03:26 PM
Critter's Avatar
o well i tried google one and it worked better. I'm just used to the normal search and i don't really like the way the google one is set up. I'l live though, nowdays i don't know if anyone ever uses the search.
marlar98
Sep 12, 2018 07:18 AM
Mikes 1994 z28
Oct 10, 2015 07:55 AM
CARiD
Sep 30, 2015 05:44 AM
autoxr166
Sep 25, 2015 04:21 PM
Fatdog2
Sep 16, 2015 11:04 PM
