1997 Trans Am no idle. P1361 + P0336, starts and runs only with throttle
Old Apr 15, 2026 | 04:32 PM
DepezPoopzie's Avatar
My 1997 Pontiac Firebird Trans Am will not idle on its own.
Codes:
  • P1361
  • P0336 (listed as moderate severity on my scanner)
P0336 has been stored/pending since I bought the car in Oct 2024. At that time the car ran perfectly with no drivability issues.
Failure event:
In fall 2025, while driving on the highway, the car suddenly went into limp mode and I lost normal throttle and transmission control. I was able to coast into a parking lot, left the car overnight, and it started the next morning and drove home.
Since that drive home, it has not been able to idle.
Parts replaced (Dec 2025 – present):
  • Battery
  • Alternator
  • Starter
  • Optispark
  • Opti harness
  • CKP
  • Ignition coil
  • ICM
  • Spark plugs
  • Plug wires
  • IAC
  • TPS
Current symptoms:
  • Hard starting (needs multiple cranking attempts)
  • Will eventually start if the fuel pump is allowed to cycle/prime
  • Will immediately stall if left to idle
  • Runs and stays running only with throttle input
  • Runs progressively better at higher RPM
  • No backfires or popping
  • Noticeably rich condition (fuel smell + darker exhaust)
Old Apr 15, 2026 | 07:42 PM
Re: 1997 Trans Am no idle. P1361 + P0336, starts and runs only with throttle
Have you checked the fuel pressure? You need to check for rapid pressure leakdown after the pump primes and shuts off.
P1361 is pointing to the ICM circuit. Have you verified the connections on the ICM?
http://shbox.com/1/4th_gen_tech2.html#opti_test
P0336 for the crank position sensor should not cause any problems, the CKP sensor was only added in 1996/97 to meet the OBD-2 requirement for misfire detection. But when the code sets you can’t pull misfire codes and data from the PCM. Have you tried to pull misfire codes and counts? The requires a scanner with GM enhanced parameters.
And a “heads up”….. 100,000++ members and hardly anyone comes here any more. Maybe a half-dozen semi-active members, most of us LT1 enthusiasts. May take a while to get responses. I’m here every day for a few minutes, but the main activity is banning spammers.
Troyl
Oct 2, 2022 10:12 PM
MTBSully
Apr 19, 2008 02:22 PM
ScreamnChicken
Sep 16, 2004 02:32 AM
Camaroz28lt1383
Nov 20, 2003 11:27 PM
KY95Z28
Nov 19, 2003 11:27 AM
