Zaino question
Old May 12, 2005 | 11:11 AM
David98Z28's Avatar
Zaino question
If I use a product for minor scratches over Zaino, should I wash it with Dawn before re-applying Zaino?
Old May 12, 2005 | 12:36 PM
'99 SS's Avatar
Re: Zaino question
I've used '3M's Finesse-It' over Zaino, and just followed up with a couple of coats of Zaino. I never washed the car after using the 3M.
Old May 12, 2005 | 01:42 PM
99andMine's Avatar
Re: Zaino question
And never never never never wash your car with Dawn or any type of dish soap!!! All that does is strip the wax off your car. Try the rain-x car soap. Works quite nicely.
Old May 12, 2005 | 02:14 PM
moparman's Avatar
Re: Zaino question
Dawn will not remove Zaino.
Old May 12, 2005 | 02:33 PM
David98Z28's Avatar
Re: Zaino question
I know not to use Dawn regularly and that it won,t remove Zaino. I know you are suppose to use Dawn to remove any type of wax before you use Zaino the first time. What I'm asking is, after you have use Zaino and use another type of product, should you use Dawn to remove that product before re-applying Zaino.
Old May 12, 2005 | 02:37 PM
'99 SS's Avatar
Re: Zaino question
NO
Old May 12, 2005 | 04:51 PM
KevinSS's Avatar
Re: Zaino question
This is not correct. If you use a product other than Zaino, whether its 3M or whatever to remove scratches on swirls, you do two things:
1. First all Zaino in that area is removed due to the abrasive action of the polish compound. and...
2. You apply oils to the paint surface where the repair was done, you do not need to Zaino over these foreign oils, you will need to re-clean that area before re-applying Zaino.
But this does not mean you need to wash the car with Dawn either all over again, simply rub the repaired area with alcohol (the rubbing kind, not the drinking kind...) and it will remove the oils from the repaired area and allow the Zaino to make a hard bond with the paint in that area.......
Old May 12, 2005 | 08:10 PM
'99 SS's Avatar
Re: Zaino question
Thanks for that info. Kevin I did not know that I should be cleaning the areas with alcohol after using the 3M I've only used 'Finesse-It' a couple of times, and followed up with Zaino to bring back the shine, and so far, the results were fine. I'll remember that for furture "repairs". Thanks
Old May 13, 2005 | 06:28 AM
David98Z28's Avatar
Re: Zaino question
Thanks Kevin.
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Hurin
Dec 13, 2014 07:38 PM
MikeLS
Dec 2, 2010 01:56 PM
RichardZ SS
Aug 3, 2002 12:26 PM
stavos
Jul 22, 2002 10:21 PM
