ZAINO Application
ZAINO Application
would you recommend using a buffer for zaino? I used my hands last time and my shoulder is still sore from three weeks ago, love the results, but the effort it takes to get it off is literally killing me.
Re: ZAINO Application
I don't understand why you had trouble getting it off. It's the easiest stuff to get off I've ever used. Some people put to much on, and then it doesn't want to dry, and it gets streaky. With Zaino, less is best.
I have to agree with 'moparman'. You may be using too much. Zaino is very easy to remove, provided you use the correct amount and let it dry at least 1/2 hr. before removing and applying another coat. Temp. and humidity may cause the drying time to be longer.
I wouldn't use a buffer either. I would read the section on towels on Zaino's website for proper towels and methods for removal. If you used the wrong towels, etc., removing Zaino, all yur work could be for nothing.
CARiD
Sep 30, 2015 05:44 AM
Aug 24, 2015 06:41 AM
Jul 10, 2015 02:23 PM
ChrisFrez
Mar 29, 2015 09:43 PM
Maroon95Z
Sep 26, 2001 08:29 PM
