ULTIMATE detailing secret......
I have found the miracle cure for that wax that has accumulated over time on your wiper cowl. A friend of mine actually pointed me in the direction, to Naphtha. At our favorite "mod" store, Home Depot, you can aquire a can of this key chemical for about $5.00. The can is large enough, you can clean your car up and give it to your friend to use.
If wanted, I will take more pics of the progress. I started with the wiper cowl, since it was the worst. I had wax on there from 4 years ago! It was nasty, and I really thought I would have to buy a whole new cowl. I started out being very liberal with the amount I used, by pouring some onto a clean rag, then spreading it around the cowl. For the spots that had heavy wax buildup, I soaked it as best as possibly.......then scrubbed with a toothbrush. The plastic of the wiper cowl will actually absorb alot of the initial Naphtha you put onto it, being as pourous as it is. You will definately need to apply a few times, depending on the amount of wax you need to take off. After cleaning to your content, follow up by using your favorite dressing. Zaino users are recommended to use tire shine, per Sal. I used my good old trusty Formula 2000.
This cleaner will work on your wiper cowl, as well as any other rubber/plastic's on your car. From the door seals, entry guards, even to your interior panels. Just be safe with the amount you use, and if you are worried, test a very small section that is out of site first.
Here is a before picture, and the bottle of Naphtha........
Now here is the finished product........
My only advice, be cautious as to how much you apply. This is an oil based paint thinner, so it is strong. The fumes arent that bad at all, but just be careful. You will be VERY impressed with the end result, I can guarantee you.
Just thought I would share.
Originally posted by tomslawsky
I just use Armorall....takes the white stuff off and shines at the same time!
Feels good for the short term, bad side effects for the long term.
Originally posted by ProjectRS
That Cant Be Good for your Paint!
On a Side Note, Did your car come with the cool Wiper Arm Covers?
My 95 Camaro had them, but my TA Dosent
Yeah those wiper covers came on the car.
Threxx:
What's wrong with Armor All? I've been using it on the cowl, weather stripping, and underhood plastic for 2 years now. I'm missing the 'giving you car crack' comparison.
Will Naptha leave a nice sheen to the plastic?
-Tim
-Tim
Originally posted by dream '94 Z28
Threxx:
-Tim
Threxx:
-Tim
If you are still not too sure about what I'm saying, use the search button and see what some of the more experienced detailers have to say about it.
Originally posted by LaSSt One
I have heard that peanut butter will remove wax residue from plastic trim...
Just puttin that out there.
Originally posted by KillerTA
I don't know what alot of you are talking about because silicon IS good for plastic and rubber. Tires turn brown because of dirt and sun, not because of silicone tire dressing.
