Don't try and get it out all at once. That usually results in taking color out of the leather.After you clean it a small amount will gradually soak into the leather and disappear after awhile.
Good luck, pen is HARD to get off. Try fine steel wool and some mild cleaner as a last resort but be careful because if you rub too long on one spot the color will come off.
