polishers/ buffers
polishers/ buffers
im in the market for a new one.
im looking for something that has variable speed and something that will go up to 3000rpms.
i really wanna get the makita 9227 but damns its expenisive.
which ones do you guys use or recommend?
Why do you want to purchase a rotary buffer? I would highly, highly advise only using an orbital buffer, you can have the Porter Cable orbital kit at Lowes for 109.00. It has adjustable speeds and you can get tons and tons of different pads for it at www.topoftheline.com
I got the PC at Lowes and ordered the yellow and oragne cutting pads, the white polish pad, and the black finish pad along with the velcro quick change backing plate from Top of the Line to go with my PC.... (PC does not come with a velcro quick change backer plate, only a white buffer pad that has to be changed with a tool)
Originally posted by Amit
whats wrong with a rotary buffeR?
Nothing if you are experienced in using one and know that you can quickly remove paint with one, and sometimes make more of a paint problem than you had to start with...
model numbers please
There are several that will do the job, I have model number 7336 but 7424 is also common:
http://www.coastaltool.com/cgi-bin/S...fb3+1067363637
you think i'll be able to use this along with the polisher?
http://products3.3m.com/catalog/ca/e...er/output_html
That pad looks like it is made for a rotary buffer, might not be too effective on a random orbit like the PC
Here are your PC pads: www.lakecountrymfg.com
Originally posted by Allen66
What is your opinion of Craftsman buffers?
Their ok, they dont make anything in the league of the Porter Cable, I think all they have is a 10 inch fixed head orbital buffer unit that uses bonnetts. I have never seen a Craftsman rotary car buffer, I dont think they make a grinder/buffer especially made for auto use...
Mr.Whitey
Dec 19, 2003 02:12 AM
