Oxidation
Oxidation
Ok so my cousins Black vette has really bad oxidation. We spent about 8 hours detailing it about a month ago. We got a lot of the oxidation off with rubbing compound and it looked great. Now the oxidation is coming back i was thinking wet sand and buffing it would make it better. I have never done either of those.
For those on here that do this kind of thing what would be the supplys to get and what kind of buffer should i get so i cant mess it up? And what grit should i use to wet sand?
might help...
i use "liquid glass" its a POLISH and really did its job on my 1993 bonneville (the guys on bonneville web site turned me on to it...ill never go back to anything else), then i used a clay bar...it was beautiful. thanks corinne
Sanding the factory finish is a gamble. There isn't a lot of clear to work with. If you insist on sanding, 2k and above ONLY. And don't try to sand it down to make it look like a show car, because you WILL burn through. I'd stick with buffing it and throwing a good coat of wax on it until you can spring for a respray. The pics look like you did a pretty good job for what you started with.
Vettenut97
Aug 15, 2001 08:21 AM
