New Paintjob, should i clay bar the car?
Old Jul 18, 2005 | 03:14 PM
Amit's Avatar
just wondering if i should go over the car with the claybar before i slap on some zaino.
thanks
Old Jul 18, 2005 | 03:26 PM
meissen's Avatar
Re: New Paintjob, should i clay bar the car?
Did you wait the 90 days yet?
This is PPG's recommendations:
In the first 90 days
It is recommended that you not wax or polish the vehicle. This will allow the finish to completely dry and cure. (When you are ready to wax, do not use silicone containing or super polymer containing waxes or polishes) Today's finishes do not need such extreme protection and if your vehicle were involved in an accident, the removal of such waxes would be time consuming and expensive.
In the first 30 days
It is recommended that you not use a commercial car wash. Stiff brushes or sponges could mar the finish and damage the surface. Wash the vehicle by hand with cool clean water only. Be sure to use a soft cloth or sponge.
Wash the vehicle in the shade only - Never in the sun.
Do not dry wipe the vehicle... always use clean cool water. Dry wiping can cause scratches.
Extreme heat or cold should be avoided. Keep the vehicle parked in the shade whenever possible.
Do not drive on gravel roads. Chipping the finish is easily done in the first 30 days.
Do not park under trees which are known to drop sap or near factories with heavy smoke fallout. Sap and industrial fallout can mar or spot a new finish.
Keep in mind that trees attract birds. Bird droppings have a high acid content and will damage a new freshly painted surface. If it happens, wash the area off as quickly as possible
Do not spill gasoline, oil, antifreeze, transmission fluid or windshield solvent on the new finish. If you do...Rinse it off immediately with water. Try not to wipe the area. If you must do so gently.
Do not scrape ice or snow from the surface. Your snow scraper will act very much like a paint scraper on a freshly painted surface.
Use common sense... If you think some substance or action may be hard on the paint, it probably will.
Old Jul 18, 2005 | 03:29 PM
Amit's Avatar
it hasnt been 90 days.. almost.
Old Jul 18, 2005 | 03:31 PM
meissen's Avatar
You might be safe after 90 days, but personally I would wait until it's really necessary.. I can't imagine and brand new paint job having that many impurities already.
Edit: If you decide to clay, try a small area that's not noticable and pay attention to the paint as you do it, make sure you use a lot of the DS to lube the clay.
Old Jul 18, 2005 | 03:32 PM
Amit's Avatar
yeah thats true.. i just have a little overspray here and there.
thansk for the info!!
siguy
Nov 27, 2014 10:07 AM
thenewkid
Nov 27, 2014 09:41 AM
USAirman93
Nov 24, 2014 03:37 PM
slothgrant
Aug 22, 2002 03:01 PM
Z28STYLE23
Aug 17, 2002 07:40 PM
