Help with engine compartment
Old Feb 23, 2004 | 05:01 PM
popoz28's Avatar
I have had several people tell me that I should not use the car wash sprayer to wash the engine and the engine compartment. They told me that it would mess up the electronics. Can someone please advise me on this. Thanks
Old Feb 24, 2004 | 02:23 PM
SSMOKEDU
Guest
Posts: n/a
I have a friend who 1st sprayed his engine compartment with Simple Green, and then lightly misted the engine compartment with a garden hose to clean it, and he had no "issues".
I've chosen to clean my engine compartment by hand though after asking around.
Old Feb 25, 2004 | 01:52 PM
PinoyPinay's Avatar
I've sprayed my engine bay (atleast 50 times) with a car wash sprayer every time I clean my car and haven't had any problems (knock on wood). Maybe, I've just been lucky. I have even set the sprayer on "jet" and "soaker" and no problems. I guess if someone can enlighten me that I am actually doing damage, I'll keep washing my engine this way.
Old Feb 25, 2004 | 02:23 PM
moparman's Avatar
If you have the LT1, the optispark could be killed by excess water from washing the engine.
Old Feb 25, 2004 | 06:32 PM
Marky82's Avatar
I spray engine-brite then hose down with a garden house (i use just the hose, no attachment at the end).
Old Feb 26, 2004 | 11:18 AM
fbird95's Avatar
simple green a rag, foaming tire shine , and wipe it down, done.
Old Feb 27, 2004 | 01:26 PM
iateyour5.0's Avatar
So...an LS1 is o.k. to spray with water? I came to the board looking for the same answer. What's the best way to clean it and with what? Doing it by hand doesn't seem to get it all' unless you wanna spend an afternoon doing it.
Mike
Old Feb 27, 2004 | 03:39 PM
popoz28's Avatar
Hey thanks everybody for your help. Sorry I did not get back to you sooner. Been real busy with work. Thanks again.
Old Feb 27, 2004 | 04:08 PM
moparman's Avatar
The LS1 is much more water tolerant than the LT1. It's the opti on the LT1 that water can play hell with. The LS1 doesn't have an opti.
Old Feb 28, 2004 | 12:38 AM
Z284ever's Avatar
Spray with Simple Green and let sit for awhile.
Then take a paint brush and agitate the really dirty spots.
Then hose off. Your goal is to simply rinse off the Simple Green and dirt, NOT TO SOAK THE ENGINE. Try to avoid over-wetting electronic parts. As soon as you're done, let the engine idle for abit to dry everything off.
Old Feb 28, 2004 | 09:09 PM
popoz28's Avatar
Do I need to leave the engine running while I let it soak and when I rinse it off? Thanks for all of the help!!!
Old Feb 29, 2004 | 12:28 AM
Z284ever's Avatar
No. Just start it up after you've rinsed off. The goal is for the heat from the running engine to dry everything off before moisture can work it's way to electrical connections and parts.
CARiD
Jan 27, 2015 06:27 AM
CaRParts102
Dec 6, 2014 08:45 AM
Chris Ja
Sep 2, 2002 10:59 AM
Timberwolf
Aug 9, 2002 11:24 AM
Darth Xed
13
Jul 22, 2002 12:45 PM
