fixing scratches at home?
Old Sep 3, 2001 | 09:14 PM
formulaofsuccess's Avatar
Question fixing scratches at home?
what's the best way to fix a scratch at home? i have one that is very thin, probably 1/16th inch wide, but runs about four feet along the rocker panel. can this be fixed some decent way with touch up paint or anything? i really dont want to take it to a paint shop if i can avoid it sense i'm selling the car shortly.
thanks guys
Old Sep 3, 2001 | 10:28 PM
$hawn's Avatar
Post
If it's too deep you will have to use touch up paint, if it's down to the metal it'll definatly need paint, or run your finger nail acrossed it and see if it catches on it, if it does you might be able to get it out maybe not, other than that i'd try some 3M swirl remover
93 Z28 Patriot Red A4
Old Sep 4, 2001 | 12:24 AM
Post
yeah it's deep enough that it's going to need paint. long, deep, but not very wide...
Old Sep 4, 2001 | 10:58 AM
mdorish's Avatar
Post
If the scratch is on the ground effects piece,you could remove the piece and have it painted (it's down so low that a no blending would be required as long as the paint is right).
If you're selling the car,though,I'd just get the proper touch up paint,clean and paint the scratch (carefully..keep paint line small),let dry,then lightly wet sand and polish.This should look OK,since it is down so low.........
The touch-up idea works better on solid,non-metallics,like black,white,red,etc.
Mike
Old Sep 4, 2001 | 12:56 PM
Post
thanks mike,
guess i'm lucky that its a bright red car. it's on the rocker panel but being a formula its not ground effects that can be removed.
Magenta_Hearts
Mar 25, 2015 10:24 AM
warmeck
Mar 22, 2015 06:43 PM
99TransAmWS6
Sep 2, 2002 11:41 AM
Timberwolf
Aug 18, 2002 07:39 PM
MislMan
Jul 19, 2002 11:41 AM
