Brake Dust
From: Somewhere between a shotgun barrel, and a blood spatter on the wall.
i can't get the stuff off anymore... when i first got my car (10 months ago) the stuff would wipe off onto my fingers with ease when just touching it... now, it still comes off on your fingers, but not all of it... to clean my wheels now i have to take them OFF and SCRUB with a semi-abrasive dishwashing thingy...
did some clearcoat come off or something?
You are not using dishwashing soap to clean them are you? I take it your wheels are painted. If so, you should treat it like the painted body of your car. They should come clean with a car wash soap and a cotton wash mit. For tough stuff, use a claybar or some bug and tar remover. Then when clean, coat them with the polish/wax of your choice. I'd recommend something synthetic as it will stand up to the heat much better than a carnuba wax. With protection on there, they will be a whole lot easier to clean next time.
As said if your wheels are painted or clear coated clean them real well with car wash or Simple Green, then I would clay them and then apply your favorite polish/wax, a synthetic polish/wax will last 4-5 times longer than carnauba wax will.
When I absoluetly can NOT get brake dust off... I use Hot Rims cleaner... takes most, if not all of it off...
If you have any stubborn little spots afterwards... try a clay bar... it worked for me.
After you are done, be sure to use something on your wheels (I use Zaino Z2)... makes future clean ups MUCH easier.
30th Anniv Z28
Aug 1, 2015 10:39 AM
