4th-gen RUST over the rear wheel well
Old Sep 24, 2009 | 07:29 AM
dougg01's Avatar
So...it's there on my '94 formula. both sides. Driver's is worse.
The body seam material is intact on both sides looking from the wheelwell.
So where is this moisture and debris coming from...? I haven't looked inside the interior sail panel yet to see if perhaps it's getting in from some other seam. I'm embarking on painting the car and found the rust. It WAS just a tiny bubble and I worked on it with a pick and poked through.
Stinks.
There are no commercially-available patch panels. I do not want to replace the whole fender.
How can a jack-leg attack this and get some lasting results....
If we could find the source of the moisture we could do something to prevent it....
Old Sep 25, 2009 | 08:06 PM
SumTingWong's Avatar
I would suggest cutting it out.
It's probably getting in at the seam inside the rear hatch channel. The sail panel wraps over and into the channel, and it leaked on mine.
You can get some 3M panel bond or Lord's Fusor from Autobodytoolmart.com and bond a piece of steel from behind, lay body filler over the top and smooth it out.
If you can weld at all, make sure you get your steel patch from a similar year GM car.
Regular commercial grade steel and HSLA do NOT like each other and you'll wind up with a molten, lumpy mess full of holes.
Old Oct 5, 2009 | 02:20 PM
slomarao's Avatar
X2, rust is cancer.
Lederman1976
Nov 30, 2014 05:21 AM
blac94Z
Nov 24, 2014 07:12 PM
squarehead
Nov 21, 2014 08:02 PM
Darth Xed
13
Jul 22, 2002 12:45 PM
dmaastr
9
Jul 1, 2002 02:22 PM
