3M 39006
Hello I was wondering if anyone used the 3M 39006 before? I think it is a cleaner,wax,and fine scratch remover just would like to know if it is any good I own a black T/A and was thinking of usig it.I know that 3M products are pretty good any help would be appreciated
That product is 3M One Step Fine cut wax, it contains alumium oxide as the abrasive, cleaner solvents, and carnauba wax. It will not last long at all on a black surface being carnauba wax. You will be better off using a straight polish compound like 3M Swirl Mark Remover part number 39009 and then as a second step using a synthetic wax or polish as a final coat. The ALL IN ONE waxes and polishes like the 39006 always produce limited results. Kinda like a a combinatation cleaner/conditioner product, how can you clean and condition at the same time?
You can see what is in the 39006 using this page: http://products.mmm.com/US/MSDS/msds...Search.jhtml.2
and type in 39006 in the trade name box and hit go.
96 Black Impala SS
Authorized Zaino Showcar Polish Distributor
www.zainobros.com
Remember #3
96 Black Impala SS
www.zainobros.com
Remember #3
Thanks kevinSS if I use the 39009 what do you think I should use as a polish and or wax/sealant I heard a lot about zanio but don't want to spend a ton of money what would be your secod best choice. Thank you
Buy a small supply of Zaino and you will not go back. I was using McGuires Gold Class (very good) but went over to the Z side. I'm sold. And you said you have a black TA....
want it to look like a mirror...zzzzzzzzz
02 35th Annv LE conv M6 SLP 345hp, 96 Z28 conv A4
<font face="Verdana, Arial" size="2">Originally posted by black97ta:
Thanks kevinSS if I use the 39009 what do you think I should use as a polish and or wax/sealant I heard a lot about zanio but don't want to spend a ton of money what would be your secod best choice. Thank you</font>
96 Black Impala SS
www.zainobros.com
Remember #3
