NIB Complete Nitrous Kit, Progressive Controller,Fuel Rails,Fuel Pump,Coil, Guages
I'm reposting some items from the past being its tax time hopefully can move them fairly quickly this time around. I bought all this nitrous equipment when I was in Iraq with big hopes, but life has shown me otherwise so I need to fulfill some other priorities first. This is no JUNK here. If one were to buy everything I had, they would have one KILLER nitrous setup. I have everything you need, but broke it down for ease of selling. If you want a good package deal, shoot me an email at speedracer2j@aol.com
1. NIB Nitrous Express EFI Nitrous Kit. Comes with a 15lb bottle, all wires, relays, lines, connectors, the WHOLE thing. Also going along with this is the Gen-X II accessory pack. It includes EVERYTHING you will need for a safe and efficient nitrous setup. Comes with bottle heater, purge valve, blow down, wiring/relays, bottle nitrous guage, switches, FPSS, EVERYTHING. To throw in with the deal, I have my Nitrous Works Ashtray nitrous switch panel. Part number for nitrous PN: 20920-15, Accessory Kit GENX-2. This stuff retails for OVER $1200 from NX. $700 plus shipping sells it. OBO
Next up is my FJO mini controller 2, gen 2, progressive controller. Also, new in the box. Never used, wired up, molested in any way.
FJO-Digital Progressive Controller
Next is a NIB Walboro 255lph fuel pump. Was going to run a dual in tank 255 setup. Selling it all, so wont need the pump. Comes with everything to run it to a second pump, hoses, filters, wiring. If I dig deep enough for a few dollars more, I can throw in the y fittings and barb fittings to complete the setup for in tank. I think I paid about $20 alone for the fittings from jegs. Paid $120 for it, sell it all for $85 plus shipping.
Next up is a set of LT1 fuel rails. Already had AN fittings tig welded on. Came with a motor I bought, but not going that route. Look great, great welds, great fittings. Will sell for $50 plus shipping.
I have a mallory 685 ignition box. It WAS wired in the car, however I had opti problems when I did it and never got anything to work out right in my favor. Mallory box is new, only mounted, never even ran it on the box. Will sell it for $150 plus shipping.
Finally, I have a couple of Autometer C2 series guages, in a guage pod. I bought these used, but they are like new, and tested that they work. I have the electronic fuel pressure guage, and nitrous pressure guage. In a guage pod for an LT1 car now. Buy the complete setup for $215 plus shipping. If you want guages only, $115 a guage, or ill throw the pod in with that for another $15. The pod is brand new.
- Laptop programmed (no dials or chips to go bad)
- TPS Voltage either rise or fall
- RPM window switch w/built in multiplier (works with any vehicle)
- Stage One Activation
- Stage 2 Activation
- Trans-brake input (No nitrous activation while applying a trans-brake)
- Low and High rpm window set points
- On or Off during the preset window
- Water tight epoxy construction
- With the solenoid driver(s) you can do the following; Stage One/two Ramp time, Turn on RPM Turn off RPM, Solenoid Frequency Adjustability
- FJO-KWS0022 P/N
Also, forgot to mention on first post. I have an MSD coil along with the ICM for an OBD 2 LT1 car. Came with my motor as well, im running OBD1 setup. $50 plus shipping takes it. All items ARE OBO as well!
Really could use the extra cash on this stuff, i've been sittin on it too long. NO reasonable offers refused! Hit me up, speedracer2j@aol.com
Jul 4, 2005 05:00 PM
