Earl's Hyperfirm Stainless Steel Front Brake Line Kit 1993-97
Old Mar 28, 2012 | 04:52 PM
tbyrne's Avatar
Set of Earl's flexible brake hoses. They are made of extruded Teflon wrapped in a sheath of tightly braided stainless steel wire. Assembled with Earl's Speed-Flex crimp and/or swaged permanently installed hose ends. Each hose is pressure tested to 4000 psi. made for maximum operating pressure of 2000 psi.
$65.00 shipped in the 48 states.
Old Mar 28, 2012 | 08:03 PM
Jlo's Avatar
Jlo
Re: Earl's Hyperfirm Stainless Steel Front Brake Line Kit 1993-97
$75.00 shipped in the 48 states.
Is this for no TCS car?? also is it front and rear?
Old Mar 29, 2012 | 01:19 PM
tbyrne's Avatar
The package that I have is the front line. Fits any of the '93-'97s.
Old Apr 25, 2012 | 06:29 PM
tbyrne's Avatar
Bump!
Old Apr 25, 2012 | 07:05 PM
slomarao's Avatar
would this also work if i went to the LS1 brake setup??
Old Apr 26, 2012 | 09:08 PM
tbyrne's Avatar
You should be fine. I found this info about doing the swap -
When I did the conversion to LS1 brakes on my 97 I bought the calipers, rotors and spindles from the LS1 car.
From there, I removed the original LT1 spindles from the control arms and swapped in the LS1 spindles then attached the LS1 calipers to that spindle along with my new slotted rotors. You will probably need to bend the original brake line mounting bracket to allow the hose to reach the caliper throughout the range of suspension travel. I think you also will need to use the LS1 banjo bolt.
(snip)
Old May 6, 2012 | 08:21 PM
tbyrne's Avatar
Available!
Old Jun 11, 2012 | 10:05 PM
tbyrne's Avatar
Bump!
Old Jul 13, 2012 | 09:58 PM
tbyrne's Avatar
Bump! $65.00 shipped in the 48!
Old Jul 23, 2012 | 09:27 PM
tbyrne's Avatar
Still available!
Brake_L8
Jan 20, 2015 09:44 AM
Jazsun
Dec 29, 2014 12:14 PM
SpeedJunkee
Dec 9, 2014 10:17 PM
Jul 4, 2005 05:00 PM
