why is my cutout....
leaking fluid when i take it off..what is it? should i be concerend? it still has enopugh back pressure it wont burn the valves right??...sorry i know there questions are dumb im just concerend
thanks boys
thanks boys
I believe that you have an exhaust bearing leak. You need to tighten the hydraulic couplings near the framinstat. This would also be a good time to check your muffler fluid to see if possibly some has leaked out. Don't mess around with exhuast fluids, if you think you're getting low, make sure you pull into the nearest dealership and let them know!
Good Luck!
Good Luck!
Sully1182
Exhaust System
30
Jan 21, 2007 12:05 PM
wow i feel retarded haha thanks dan
uh oh
