Pacific Alaska, California, Hawaii, Oregon and Washington
Wet Noids
Old May 26, 2003 | 11:06 PM
Tw!tchb!tch's Avatar
Wet Noids
How much do wet solonoids cost Also anybody know what a couple powershot noids would cost off the to p of your head / heads
Old May 26, 2003 | 11:36 PM
sideways_Into_3rd's Avatar
u want more nitrous u freak ???
get ur 125 shot to hook first then go after more .. unless u wanna do the sideways_Into_wall mod
Old May 27, 2003 | 02:35 AM
zturbo's Avatar
Are you wanting another stage or to just turn your dry into a wet shot?
I would give Jeff Prock a call as he IS one of the best in nitrous systemsApplied Nitrous Tech (jeff prock)
Steven
Old May 27, 2003 | 07:47 PM
I think Im going to run a second msd window switch and a wet solonoid that kicks in with the existing one
3000 rpm 75 shot + .2? wet jet ( to cure going lean )
4000 rpm 75 shot second stage
This will cure my lack of traction and fatten my weak *** power curves
I may upgrade to the nozzle setup eventually
Old May 27, 2003 | 10:26 PM
zturbo's Avatar
So you are going to run another complete setup for the second stage i take it.
You might want to take a look at the maf setup from NX. Really is a nice piece from everything i saw.
Steven
Old May 27, 2003 | 11:02 PM
Well really I can use my nos system to power everything I just have to ground the second set of noids through another window switch pilled from 4000 - 6000 for the seperate ground loop but I can use my wot switch and arming setup . . .Should be cake
NX MAF
Old May 27, 2003 | 11:13 PM
zturbo's Avatar
You lost me here a lil bit...
You have one stage 75 shot...
then you are wanting anothe 75 shot.. How are you going to stage two of these to come on using one nitrous selenoid ? I prob am reading it wrong, but if you are wanting a wet shot as well i would just get a base kit minus bottle, or get a few parts and build your own setup as you don't need some of the lil things
karpetcm
Sep 15, 2015 11:07 AM
4586
Aug 22, 2015 01:09 AM
4586
Aug 18, 2015 07:08 AM
meissen
Aug 11, 2015 06:05 AM
Boss002
Jul 9, 2015 03:33 PM
