Pacific Alaska, California, Hawaii, Oregon and Washington
Tire pressure and rotating
Old Apr 29, 2004 | 03:49 AM
Drumhawk's Avatar
My 275/40/ZR rear tire pressure runs low after a few weeks on one tire, what's up? I also went in for my 15K tire rotation that is recommended in my car manual, I was told at a shop that they don't need rotation cause the fronts have a touch more tread than the rears, I guess some of my launches have worn down the rear tires more so no rotation needed. They said it's better to have more tread on the front for turning corners. I felt the tread lines of the front and rear tires have lots of tread left on both. they felt quite even on wear to me.
Old Apr 29, 2004 | 12:13 PM
BennyBoy's Avatar
If you are losing pressure in one tire, maybe your valve has gone bad on that tire. As for rotating... I never do it because I always cook off the rears so much faster than the fronts. I would rather replace two tires at a time than 4. Although, it is usually cheaper (per tire) if you replace 4 tires than 2.
Old Apr 29, 2004 | 06:51 PM
Camaro ChriSS's Avatar
Sounds like you might have a small leak - either stem or seal around wheel rim. May be tough to trace, but if they submerge it, they MAY find it. Not always though.
I still like to rotate my tires (though I don't now that I run DRs on the back) just to keep the wear even. Even though it's good to have more tread up front for handling, I don't find the car handles too well when the backs are worn down a lot more than the front.
You don't have to do a rotation, but if you start to find a slight vibration at higfher speeds through your steering wheel, likely its becuz your tires are wearing unevenly and need rotating.
Of course, remember the tires are directional.
Old May 1, 2004 | 12:18 AM
Amit's Avatar
sounds like you are having a small leak there..
its good to rotate them bad boys every 10k..
what tire pressure you runnin Steve?
i'll be rollin on some 285/35/18's soon..
Old May 1, 2004 | 12:33 AM
KA0S's Avatar
Re: Tire pressure and rotating
Maybe ease up on allowing fat chicks in your car. I can imagine the tire bulging now.
Old May 4, 2004 | 01:43 AM
Drumhawk's Avatar
Re: Re: Tire pressure and rotating
Now who would that be?
Old May 4, 2004 | 01:45 AM
Drumhawk's Avatar
Originally posted by Amit
[B
D [/B]
My 275/40ZR's have a rated max tire pressure of 44 but I run around 38.
Old May 4, 2004 | 07:38 PM
Amit's Avatar
wow.. why so high?
recomended tire pressure is 30 psi
RichJ
Sep 14, 2002 09:37 AM
Frank95z
Sep 10, 2002 08:30 PM
97bowtie
Aug 25, 2002 11:00 PM
Cap'n
Aug 19, 2002 11:33 PM
wytblur
Aug 5, 2002 02:03 PM
