Pacific Alaska, California, Hawaii, Oregon and Washington
Timing tunner and maf translator Q
Old Jun 8, 2003 | 09:00 PM
Tw!tchb!tch's Avatar
K , Ive got perfect air fuel ratio throughout the powerband n/a and am eventually going to purchase the timing tunner which has a trigger switch so you can swap between two settings , eg up a couple degrese extra advance around town n/a and then when you hit the nitrous it instantly activates the timing tunner through the trigger giving you your specified retard while you squeeze .
So my question is . . . could you use the timing tunners trigger to also piggyback a maf translator . eg same scenario except ontop you activate you maf translator to fatten up your mixture 10 % or so while your spraying ( only when triggered )
pete53
Dec 9, 2014 07:31 AM
formula218
Dec 2, 2014 04:27 PM
ScottZ
Mar 3, 2004 01:34 PM
97FormulaWS-6
Sep 11, 2002 11:57 AM
MIGHTYMOUSE
Aug 29, 2002 09:18 AM
