Pacific Alaska, California, Hawaii, Oregon and Washington
Stage 8 bolts
Old Jul 3, 2003 | 06:33 PM
BennyBoy's Avatar
Stage 8 bolts
I will be installing some RK Sport headers into my car within the next week or two, and I was wondering whether I should get the 3/4" Stage 8 bolts or the 1" bolts. I shouldn't need anything other than bolts, WD40 (to remove bolts), and some gaskets... right? I have the stuff to block off and remove the AIR and EGR.
Thanks guys
Old Jul 3, 2003 | 06:42 PM
Draco's Avatar
I tried using Stage 8 bolts on my RK Sports.
Some of them would NOT fit due to the size of the bolt head (primaries were in the way).
You might be better off saving money and just running ARP header bolts.
Old Jul 4, 2003 | 10:29 AM
BennyBoy's Avatar
Hmmm... that's good to know. Is there anything I can do to prevent them backing out? Can I use lock washers?
Old Jul 4, 2003 | 11:07 AM
Draco's Avatar
I personally havent had a problem with my bolts backing out. I just tightened them down after 50km and they havent come loose.
Not sure if lock washers would help that much
Old Jul 4, 2003 | 12:30 PM
JD30thZ28's Avatar
You won't have any problems with them backing out, just get some 3/8 ARP header bolts, after a few days of driving re-tighten everything and you will be fine, I have used these on the three sets of Headers I have had with no problems
Old Jul 4, 2003 | 12:46 PM
BennyBoy's Avatar
OK, one last question to harass you guys with.
3/4 inch or 1 inch length?
Edit: I think the 1 inch are the ones to get. Someone correct me if I am wrong... lol
Old Jul 4, 2003 | 12:57 PM
JD30thZ28's Avatar
Don't remember that one Although I can check that for you tonight. Installing FLP's On Perry's Camaro.
Old Jul 4, 2003 | 01:54 PM
BennyBoy's Avatar
OK... I don't think ARP makes a 1 inch bolt... lol. I am going to get ARP part # 400-1101.
http://www.arp-bolts.com/media/pdf_files/header_bt.pdf
Old Jul 4, 2003 | 02:29 PM
JD30thZ28's Avatar
3/4 length is right
Old Jul 4, 2003 | 03:38 PM
BennyBoy's Avatar
Thanks. Good luck with the FLP's.
Old Jul 4, 2003 | 05:53 PM
spo/z mike's Avatar
lets see some pic's of perry's ride
maybe2fast
Mar 16, 2015 09:45 AM
DirtyDaveW
Mar 15, 2015 07:01 PM
importkiller94
Jan 17, 2015 09:03 PM
