Pacific Alaska, California, Hawaii, Oregon and Washington
shifting problems (with an auto lol)
Old Jun 15, 2003 | 11:51 PM
zman0069's Avatar
ok... my car just decides to keep revving unless i release the gas. wont shift too easily usually problem from 2nd to 3rd, ie i was at the line with a new mustang gt, had quite a bit on him...suddenly my car stops accellerating.... it does this every now and then... i know i have to change the seal on my differential cuz of a minor leak.... now im thinking... time for changing gears or tranny problem??
Old Jun 16, 2003 | 12:02 AM
todd15's Avatar
opti,coil
Old Jun 16, 2003 | 12:10 AM
TyphoonZR's Avatar
zman, if the tranny won't shift into third, try moving the shifter from the second position to the third (D)! I have done this several times with great success!..... and yes, it is time for changing gears!
Old Jun 16, 2003 | 12:14 AM
zman0069's Avatar
tried this makes no diff still revs till i release the gas.... and does anyone know a good install place for gears?? lol and know where to get a good set of gears prolly stick with 3.23s or go to 3.73s
Old Jun 16, 2003 | 12:27 AM
irocz383's Avatar
Sounds like you might have a problem with the valve body...
If it is its not too bad they can fix it or replace it without even pulling the tranny!
While their in there might as well get a shift kit and corvette servo put in!
Old Jun 16, 2003 | 01:13 AM
Mad-Max18's Avatar
i get that to i have a 87 ta and if i hammer it it will just rev up and not shift i have to let go of the gas it sucks
Old Jun 16, 2003 | 03:10 AM
Jacks_Z28's Avatar
Hey Zaid, does this happen only when you punch it? Or does it happen when your doing regular driving too?
Old Jun 16, 2003 | 05:08 AM
zman0069's Avatar
only happens when i punch it from the line or whilst moving
Old Jun 16, 2003 | 11:26 AM
JD30thZ28's Avatar
Arrow
Time for a Tranny Re-Build
Check your tranny fluid first
Old Jun 16, 2003 | 12:29 PM
BennyBoy's Avatar
This was happening to me almost 2 years ago, shortly after getting my car. It got worse until the tranny would make a horrible noise when going into 2nd at anything over 1/3 throttle. I changed the fluid and filter and it didn't make a difference unfortunately. Took it in and had a new tranny put in under warranty.
I would change your fluid and filter asap. My car hesitated when shifting into 2nd at WOT the other day. I will be changing my fluid and filter very soon. I also have a tranny cooler I am going to put in.
Old Jun 16, 2003 | 01:17 PM
Jacks_Z28's Avatar
Does it backfire or pop when this happens?
Same thing happened to me a year or so back, I thought I was gonna have to rebuild the tranny, turns out it was just the coil. Hope this is the case, good luck.
Old Jun 16, 2003 | 01:44 PM
BennyBoy's Avatar
Yeah, definately check the ingnition components as well: wires, plugs, coil. When I first got my car it didn't want to go over 150km/h. It felt like a rev limiter in there. New plugs fixed that...
Old Jun 16, 2003 | 02:09 PM
bunker's Avatar
Ok Jack enough out of you, you were hitting a majical rev limitier that wasn't a rev limiter, you're tranny wasn't shifting cuz you never reached the preset shifting RPM due to your misfire.
Old Jun 16, 2003 | 04:53 PM
zman0069's Avatar
i think i shud be changing the fluid soon so ill have that done... and as for the poping sound nope, doesnt doo that unless the revs are really high and i tap the gas... for normal driving its completely fine just those odd times when i need to punch it..plugs were just changed the wires were check at the same time.... ill take it to gm for normal service neways and c what they say...
Old Jun 17, 2003 | 12:26 AM
Jacks_Z28's Avatar
Exactly, HENCE I thought it was my tranny. Now if your not gonna stay on the topic (helping this guy out), Big Mike is gonna come get ya,Post *****
PCLZ28
Dec 24, 2015 05:19 PM
jb4xx
Feb 2, 2015 10:00 PM
tds1213
Nov 27, 2014 12:55 PM
Sarahrope64
Nov 27, 2014 11:17 AM
