Pacific Alaska, California, Hawaii, Oregon and Washington
Question for the LS1 boys
Old Jun 26, 2003 | 07:55 PM
NiteRider's Avatar
Just wondering ladies, what octane do you guys run in your beasts?
Old Jun 26, 2003 | 08:04 PM
Amit's Avatar
beast.
not beats.
i run JET FUEL in my cavalier.
supa powaaaa!!!!
Old Jun 26, 2003 | 08:05 PM
NiteRider's Avatar
Originally posted by Amit
beast.
not beats.
supa powaaaa!!!!
Hey thanx for the typo heads up, you ain't a LS1 boy, beesh..
Old Jun 26, 2003 | 08:28 PM
Tw!tchb!tch's Avatar
94. . . why ??
Old Jun 26, 2003 | 08:43 PM
TravWS6's Avatar
anything
i'v ran everything and anything.. i stick wit chevron.. sometimes she runs like sh*t with low octane.. but i also got a HPP3.. that requires 92 i think. o well
Old Jun 26, 2003 | 08:44 PM
talos's Avatar
Re: anything
hi
Old Jun 26, 2003 | 08:48 PM
ls1_bc's Avatar
Chevron 94 octane since day one.
Old Jun 26, 2003 | 08:50 PM
silversupersport's Avatar
depends on what gas is at. if its reeally high i run 92 otherwise i usually run 94 both from chevron "you're town pump"
Old Jun 26, 2003 | 10:29 PM
mr_muff's Avatar
chevron premium 94 only
but you can run them on 92
Old Jun 26, 2003 | 11:10 PM
NiteRider's Avatar
Interesting feedback, I figure only the two Mikes should be runniing 94, mike p and mike s, I thought you guys would be running 89 when the prices are really high and 92 when there not so high.
Damn, you guys pamper those engines to much.
Old Jun 26, 2003 | 11:25 PM
Camaro ChriSS's Avatar
Good god... 89??? Never. Chevron 94 always. The car is not recomended for less than 91 (not that the manufacturer's recommendations are a big deal), and with a ported MAF, like i have, it is very common to get detonation with 91. Hence, 94. 92 is likely to have no noticeable negative effect, but I like the good stuff.
If you drive like a granny, then you might use cheaper gas and never know the difference - but who drives like that? In the whole scheme of things, the cost savings is COMLETELY insignificant in my opinion.
Some LS1 years are better too than other years for handling different octanes (at least it SEEMS to be that way), depending on the programming from the factory. Later years are supposedly not as good with lower octane. But, I've never seen this firsthand.
Honestly, I don't know how much of a diff it would make on the dyno or mileage - but if you have any form of a ported intake, or anything else that advances the timing, then 94 is a safe choice.
Old Jun 26, 2003 | 11:26 PM
TravWS6's Avatar
haha i argee wit u niterider!! i only run 89.. 94 when the big checks come in... y do it if ya don't have to right?
Old Jun 26, 2003 | 11:30 PM
TravWS6's Avatar
u got a good point there Chris.. personaly i listen to the motor.. put the gas in.. if it makes noises and doesn't run well i steep up the octane.. but ya for sure if im out to have some fun i put good stuff in!
Old Jun 26, 2003 | 11:33 PM
sleeperZragtop's Avatar
94...always or else...ping, ping, ping
Old Jun 26, 2003 | 11:38 PM
93formula's Avatar
that ping ping ping may be the famous ls1 piston slap
