Pacific Alaska, California, Hawaii, Oregon and Washington
Over 500 RWHP plus/problems
Old Dec 17, 2003 | 04:39 AM
upgradedsupra's Avatar
You are probably thinking > where is the sheet? No numbers released until I get everything fully confirmed on what I have to do. I am going on a dyno jet to see if we can make sure everything is correct. For the amount of boost I ran I believe the numbers should have been higher. I will say that it is over 500 rwhp but I want to see what I get on the dyno jet first. Some people say that the dyno dynamics takes out more or reads lower. I have always used the dynojet and generally used the one today for tuning. Now to get the true numbers.
The wastegate spring was a problem and the Nitrous wouldn't work either. man what a day. The one time I actually want to spray, it wouldn't work Grrrrrrrrrrrrrrrrrrrrrrrr
Jason > when we put the new spring in the waste gate , it stuck on the way home. I rerouted it and we have it fixed. No more 30 pounds until I get the new spring or get a better one that actually fits LOL
Oh! and > Shhhhhhhhhhhhhhhhhhhh Not yet
I will post pics of the dyno sheet after I confirm a few things on the dyno jet.
PS: After speaking with 2 buddies of mine says the same thing. He expected bigger numbers so > having said that > I will see what happens
Duane
Old Dec 17, 2003 | 07:42 AM
OneFlyn95z28's Avatar
Good luck man! Stay on top of that AFR!
Old Dec 17, 2003 | 08:39 AM
blue 79 Z/28's Avatar
hey duane, i got the pics on my com now, whenever you want them let me know. today was fun, turned into an all day event but i had a fun time.
Old Dec 17, 2003 | 08:50 AM
ollie-99's Avatar
Good luck w/ that duane
Old Dec 17, 2003 | 12:08 PM
oldschool's Avatar
Good luck bro,
I'm not much of a fan of dynos because their readings vary so much. The only really test of a cars power is on the track. I wouldn't care if the dyno I do my tunning this year didn't have a hp curve. The A/F are the readings I want anyways.
Andy
Old Dec 17, 2003 | 01:06 PM
Originally posted by oldschool
Good luck bro,
Andy
the only dyno i like is a progressive acceleration engine dyno, that will give you the real deal and is the utmost in accurate. but for most it is too hard to get done, and is pricey. but its just what i like
Old Dec 17, 2003 | 01:54 PM
Muskys SS's Avatar
Good to here your working out all the bugs!!
I came down with a bad cold and couldn't make it on tuesday. Hopefully next time you go to the dyno I'll be healthy enough??
Old Dec 17, 2003 | 06:13 PM
I am heading down to seattle to see what the dynojet puts down. Get back to you later.
Jason > send me the pics!!!
Duane
Any good ones?
Old Dec 17, 2003 | 06:18 PM
PM'd, contact me
Old Dec 17, 2003 | 09:31 PM
Hey let me know when your are heading down. I would like to see that puppy
Old Dec 17, 2003 | 10:13 PM
Hey > I am heading down on 9 o'clock Saturday. I will be there around 11 oclock and will be dynoing around mid afternoon.
Duane
1800.421.9390 if you need to call me. I am at the offive now as well
Old Dec 18, 2003 | 01:58 AM
Drumhawk's Avatar
Good luck, watch out for heavy border line ups this saturday. It being just before christmas and all. Any saturday morning is lined up for 1 or 2 hours. Give yourself plenty of time, go get um.
Old Dec 21, 2003 | 12:19 AM
The car did a good run at 490 at 23 psi and 528 torque, with the wrong map. I have one for pump gas and one for race gas. The timing is much higher on the race gas map. Ron's laptop battery died and could not upload the other progam on the TEC. The car would have put out over 500 with ease if we had done that.
As we spoke I gave out the secret. The other dyno run he hit 515 wheel hp and didn't want to say anything because I ran 33 psi. I knew that the car had more in it.
So at 10 psi less I ran almost the same number and could have run the same if we had the fuel map uploaded.
No more boost as the wastegate spring was maxed out. I wanted to hit that high 550 rwhp mark but with this problem could not.
No nitrous because the guy had been empty. No spray kit for the intercooler either.
So, 490 and 528 is a good number. We know that this turbo will hit over 550 with the new map which we will upload today. Get a new spring, some nitrous and go back to the dyno in a month.
Nice bike by the way Trey.
Thanks for coming along Dave as well.
We have it on video and will post it asap.
Also, even though I had hit the 500 mark already, I do not want a spot on the 7MPOWER just yet I want the third spot first.
Duane
Old Dec 21, 2003 | 03:11 AM
The Watcher's Avatar
Nice numbers
right now you should be in 6th and very close to third with the right tune, but i want to see you go for first
Old Dec 21, 2003 | 09:57 AM
Erik's Avatar
Classic Tech Moderator
Thumbs up
eh. Not bad, I guess.
Seriously though, it's cool that that turbo is finally looking like it's going to put down the numbers it should. Now I'm looking forward to seeing how it runs at the track
