Pacific Alaska, California, Hawaii, Oregon and Washington
Opti Help
Old Nov 9, 2004 | 01:32 PM
bzeilstr's Avatar
Opti Help
I've heard about it but never experienced it. Stumbling around 2000 RPM. Occasional surging at idle. I'm thinking optispark. I had it apart last winter when I had to change a leaky water pump. I wanted to make sure it was clean and dry so I took it apart. It was dry but not very clean so I cleaned it and sealed the housing with silicone when I assembled it. Worked fine up until about a week ago when I started having these symptoms. Am I diagnosing correctly? Suggestions? I'm thinking this is very expensive.
Bill
Old Nov 9, 2004 | 07:53 PM
93formula's Avatar
Re: Opti Help
well if you had water in it then its just a matter of time before it went. did you use dielectric grease when you put it back together? i say get someone who would know what it feels like to take a ride with you.
Old Nov 10, 2004 | 02:19 PM
BPS's Avatar
BPS
Re: Opti Help
Sounds like it - mine use to stumble and backfire and then drive fine for a while - this lasted about a month until it left me stranded on the highway.
Repairs - figure ~$1,100 at the dealer, $450 to do it yourself.
Old Nov 13, 2004 | 03:50 PM
bzeilstr's Avatar
Re: Opti Help
Well that's a great trick. After all that I decided to try the obvious and check the connection to the opti. I pulled it off and had a look. Saw nothing so reinstalled it. Now it runs fine. Must have had a bit of corrosion on one of the contacts. Beats a re and re any day. Anybody else had this happen??
Formula Steve
Sep 19, 2023 08:31 AM
94Maroz28
Oct 27, 2015 04:38 PM
Ks0209
Oct 1, 2015 07:32 AM
colts0455
Sep 27, 2015 01:07 PM
jayblev95
Sep 26, 2015 09:44 PM
