Pacific Alaska, California, Hawaii, Oregon and Washington
new panasonic deck
Old Oct 29, 2003 | 01:03 PM
1quickgt's Avatar
new panasonic deck
got a new deck for the ride its the panasonic cqdf783 mp3.c.d deck it's chrome wiht colbalt blue lighting dont knwo if ya seen it around but anyways just wondering if anyone knew about it and had any feedback?
thanks
Old Oct 29, 2003 | 03:08 PM
talos's Avatar
nice deck, from what i have heard if ur replacing the stock deck ur going to have to change around the wiring or something.... i heard the bose wiring will not fit.
Old Oct 29, 2003 | 03:56 PM
1quickgt's Avatar
thanks bro yeha you gotta get a bunch new wiring and **** for the amp and sub to work....stupid gm
Old Oct 29, 2003 | 05:42 PM
NiteRider's Avatar
You just need a adapter and it will work just fine. Your mid section subs will not work.
Could have spent your money on go fast parts, tisk tisk.. AHEM, headers...
What was the retail on the deck anyway?
Old Oct 29, 2003 | 06:32 PM
SBainsTA's Avatar
Actually u should have no problem running your new deck with the stock system even with the adapter. I never had an issue even with the sub and amp. And all of the speakers worked. the only thing that won't work is the steering controls unless you get the adapter for it. If i remeber correctly the mid speakers are hooked up to the rear and fronts and the when you fade to the rear there is a less of an impact, whereas if you fade to the front, the mids cut out more.
Old Oct 29, 2003 | 09:04 PM
NiteRider's Avatar
I belive the deck may over heat or blow fuses with those subs conected. Either way the stock subs are crap and you should be running a nice 10' with a stealth box.
Old Oct 29, 2003 | 10:29 PM
93formula's Avatar
or a Q logix box with two 10s!
Old Oct 29, 2003 | 10:45 PM
1quickgt's Avatar
yeah thats what im worried about the sub and amp...i guess we will see soon enough....and the retail armen is msrp 469.95...but i got a bit of a deal on it ..and man your headers and my next buy dont worry soon enough
Old Oct 30, 2003 | 11:04 AM
SBainsTA's Avatar
ummm, how do you plan on hooking this up? All you have to do for the deck is plug and play if you get the addapter. As for the subs an amps, are you getting aftermarket? If so, there will be no issue. I ran my deck with the stock speakers and just the adapter for a whle, and I had no issues.
Old Oct 30, 2003 | 12:52 PM
1quickgt's Avatar
alright...i just hope i dont screw anything up but yeah i just hope it works wiht the stock system for now anyways
alex5366
Jun 8, 2015 07:52 PM
Z28STYLE23
Aug 17, 2002 07:40 PM
Reg Kmet
Nov 17, 2001 08:24 AM
Reg Kmet
Nov 15, 2001 12:33 AM
