Pacific Alaska, California, Hawaii, Oregon and Washington
Man, finally I can't stand doing trannies!
Old Aug 3, 2003 | 02:45 AM
bunker's Avatar
Finally after about 4 hours of trying to put the tranny/flywheel etc... on, it took like 2 hours to get the tranny into the darn car, its heavy, & being 1 person it doesn't help so I got my dad to help me push the thing around while under the car. I think its in properly, I don't know, having to only of done automatic trannies this is my first M6, I put the flywheel on, new pilot bearing, disk/pressure plate & proceeded with the tranny, now I'm wondering, I guess if its all the way on then its on properly ? all I know is I can't turn the driveshaft in gear while in neutral it turns so thats a good sign then the fork was all weird, it looked funny, kept on wanting to nudge out, so hope it work, I have to ask someone that did the slave cylinder just on how it looked when they mated their on. well anyways I hope the thing is on properly, like I said I guess it either goes in or it doesn't. Also, having only 1 jack doesn't help either.
Bahh, anyways tranny seems to be in & connected with driveshaft & all wiring.
Old Aug 3, 2003 | 02:55 AM
sideways_Into_3rd's Avatar
dude congrats on ur tranny job
make sure when ur putting on the slave cyl that ur fork is sittin on properly .. that damn sonofabeesh comes off easy .. so hold it in place befor eu put the slave in and it'll be fine
if the bellhousing bolts go in all the way ur ok .. there are guiding studs that suck the tranny in properly the way it suposed to
anyway
im way drunk and tierd and i must goto sleep .. good luck with the rest of the **** .. i'll be home tomorrow .. but no time to come help yah till aug 8th
if the bolts are in and the damn thing is sitting straight ont he motor then ur fine .. once u put the rst of ur motor toether and get the thing on trhe road u'll knowif it is ok or nto ..
any way .. im outtie
i'll ttyl man - GGGGGGGGGGGGGG
beesh
Old Aug 3, 2003 | 03:22 AM
bunker's Avatar
hehe, cool yesh, I made sure the slave was kinda just nudged in there, cuz it kept on wanting to come out just a bit when putting the slave on, but basicly I kept it in while putting the slave cylinder on, I'm just wondering if thats good & if it'll fall off or nudge out again or something ? Hope not.
BTW thanx on the congrats.
Old Aug 3, 2003 | 03:24 AM
ollie-99's Avatar
Good Job Matt
Old Aug 3, 2003 | 10:04 AM
97TA-WS6-Con's Avatar
You changed a tranny on your own with one jack man you are fearless.
I know Cory does it but I do not know what he has to face.
ps: Anytime after 1.00 today I'm home.
Old Aug 3, 2003 | 10:40 AM
Draco's Avatar
Man I feel bad about not being able to help. Good to hear that you got it in.
give me a little more notice and I can help with these things. It's just that I am on my first "holiday" from work in 2 years and I didnt want to break my plans for the weekend.
Old Aug 3, 2003 | 11:26 AM
bunker's Avatar
K thats cool, so ok I'll be down at your place around one then Shawn thanx so much But hey Shawn can you send me directions on how to get to your place or post them? Thanx, I kinda fergot I know I exit on 176
Also, I was getting so frustruated I kept getting angry & taking the tranny off the jack & lifting it under the car, now every part of my body is soar including my neck
Old Aug 3, 2003 | 11:30 AM
CoryM's Avatar
Glad to hear its in Matt. If its all the way in, its all lined up in there. The only thng to watch is that there is no gaps between the bellhousing and engine. Ive seen guys get wires etc stuck in there and then the bellhousing breaks. As for the slave cylinder Im not sure what you mean. Doesnt it just bolt on with 2 bolts? This transmision has a slave cylinder on the outside right? not one of those ones that goes over the front bearing retainer. IF its on the outside you just need to make sure that the rod goes into the hole. I do not remember if there is a spring holding the rod in or not. And yes Shaun, mine is pretty stinking easy. I use a whole 5 tools and have to remove 12 easy bolts. Takes about an hour to re&re the tranny.
What does a T56 weigh anyhow? Id like to know how much weight I will save in my truck by going to one. The current tranny is 180lbs (and yes I benchpressed that pig in and out 3 times)
CoryM
Old Aug 3, 2003 | 11:44 AM
Tw!tchb!tch's Avatar
Good job
I remember when I was swapping a budies tranny in my driveway I almost squashed myself to death haha !! I was like " just drop her down om my chest and Ill wiggle out . . . yup lower . . lower . . . lower . . . OWWIEOWWIEOWWW !! HIGHER !!HIGHER!! HIGHER !! Those things are fawkinh heavy
For anybody that needs a new clutch etc done , Randy from work is awsome . Hes doing my spec III and flywheel probably this winter and just did a ws6 last month . They only charge 5 hours and on the hoist with the trany jack its guaranteed to be perfect , Randy is very very maticulous (sp )
Old Aug 3, 2003 | 11:55 AM
bunker's Avatar
Thats cool, I think I know a shop around here that will do it for around $250 but my car is in pieces & it wasn't just a clutch mod, its cam/lifter/rev kit/rear end/flywheel/tranny etc.... rockers bah too much crap.
As for weight I'm not sure but prolly around 200lbs, what helps is its alluminum but its still darn heavy, but whatever I'm strong
Old Aug 3, 2003 | 12:55 PM
CoryM's Avatar
Id guess more like 130lbs max for a T56. My trucks tranny is all cast iron and has gears 1.25" thick and 1st gear is about 6" across. Lookslike it belongs in a tractor. It only weighs 180lbs. Theres no way a T56 is anywhere near that weight. Just found out the T56 is only rated for a 4000lb vehicle. Id better get the weight down.
CoryM
Old Aug 3, 2003 | 05:10 PM
LuCiFeR97Z28's Avatar
Matt, you're a beast . Glad to hear of the progress!
FWIW, my old 4L60E (A4) was about 140lbs, so the T56 shouldn't be more than that...I'd guess 110lbs.
Old Aug 5, 2003 | 08:33 AM
bunker's Avatar
I think the M6 is heavier then the A4 considering its full of gears.
bunker's Avatar
Old Aug 5, 2003 | 01:30 PM
Hmmm I didn't know that...I always thought the auto tranny had more "moving parts" than its manual counterpart .
