Pacific Alaska, California, Hawaii, Oregon and Washington
lowering question
Old Nov 5, 2003 | 11:34 PM
1quickgt's Avatar
lowering question
alright say im putting 18's on my car how much of a drop will be needed and how much woud it cost? will eibach's pro kit work (lowered 1.3 in all around) thanks..oh the stock wheels are 16's
thanks again
Old Nov 6, 2003 | 12:39 AM
Draco's Avatar
The overall diameter of your tires should be the same (the tire sidewall will shrink as the rim size increases). To make it look good you will need to drop at least 1" - most people go for 1.5" or so of drop.
Old Nov 6, 2003 | 12:43 AM
1quickgt's Avatar
cool thanks craig
Old Nov 6, 2003 | 02:10 AM
JD30thZ28's Avatar
I say go for 1.5" drop
Old Nov 6, 2003 | 01:46 PM
ianwells100's Avatar
hey craig, as in 1quickGT, where are you getting the springs from, and how much are you paying?
Old Nov 7, 2003 | 01:58 AM
mr_muff's Avatar
i have the supspension techniques springs and i am pretty sur emy car is lower with them, than any of the eibachs will go. but my car is like driving a brick because of them. never bottomed out or rubbed a tire or anything though. they are STIFF
i think it is lower than what they are rated at because compared to other fbods, i think mine looks lower.
Old Nov 8, 2003 | 01:30 PM
1quickgt's Avatar
yeah theres so much stuff out there....ian i ahve not got the springs as of yet so i dont know what i am going wiht or how much they will be...but as just posted suspention tequniques sounds to be better then eibach.
Old Nov 8, 2003 | 01:55 PM
Tw!tchb!tch's Avatar
Your car is already pretty low for stock . I say get some koni sa shocks for the front and run them on the lower perch and remove the rubber spacer out back with some compressor hose / heater hose or something a bit softer and spend the dough on some koni's for the back too when you can afford . That will give you a 1/2 - 3/4 inch drop and ten times the handleing benifit . The stock shocks suck *** bigtime and should be the first suspension mod imo .
Noenav
Mar 1, 2019 07:38 AM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
oldschool
Feb 9, 2016 09:21 PM
HectorM52
Jan 31, 2015 07:29 PM
