Pacific Alaska, California, Hawaii, Oregon and Washington
4th Gen Tranny Swap
Old Oct 3, 2003 | 10:39 PM
hishameen's Avatar
4th Gen Tranny Swap
A quick question...
How difficult & how much money would it cost to swap a manual tranny into a 4th gen z28?
EDIT - The transmission is currently an automatic.
Old Oct 3, 2003 | 11:41 PM
TyphoonZR's Avatar
I beleive you can buy a tranny for about a grand from the wreckers and it would take about 6 hours time to re and re. You might want to consider replacing your clutch and pressure plate at the same time, if your current tranny needs replacing! Actually if you're good, you might be able to do it in four hours!
Old Oct 3, 2003 | 11:44 PM
hishameen's Avatar
Actually... I might of forgoten to mention that the tranny is currently an auto.
Old Oct 4, 2003 | 11:08 AM
TyphoonZR's Avatar
hehehe, yes you did, and I took advantage of your error. I knew what you meant, but I thought I would have a little fun at your expence.
Old Oct 4, 2003 | 01:34 PM
Pandamonkey's Avatar
All I've ever read about this swap is that it's sooo much better to just look a bit more and find one with a 6-spd to start with.
That would be the most cost effective way.
There has to be a car out there with everything you want man......don't settle just because you are anxious.
You'll find the one.
Old Oct 5, 2003 | 01:55 PM
LT1Z28's Avatar
Done the swap once fairly straight forward just requires time and all the right parts.. Probably 6 to 8 hours if you have all the pedals crossmembers etc
Later
Mike
Old Nov 8, 2003 | 07:19 PM
CHRISCAMARO's Avatar
i was looking to go from manual to auto
is that hard to do and what costs
hish-what year do you have?
Old Nov 9, 2003 | 12:46 AM
LT1Z28's Avatar
If you have the parts its easy little bit of wiring and little bit of cutting did the swap a couple of years ago for a freind. Basically all you need is the flexplate tranny m6 crossmember and the pedals. Tools required sawzall hole saw etc. If interested i Can do the swap for you guys just have quite a few jobs on the go at the moment.
Later
Mike
HOFFICER
Apr 6, 2020 10:36 AM
Magenta_Hearts
Mar 30, 2015 09:42 PM
nballisru
Dec 14, 2014 05:01 PM
Doug Harden
11
Jul 14, 2002 04:31 PM
