Pacific Alaska, California, Hawaii, Oregon and Washington
I need somehting to cut...
Old Feb 6, 2003 | 12:39 PM
irocz383's Avatar
Does anyone have an open shoe grinder with a cutting wheel?
Air or Electric. I can use either.
I need something along those lines to cut a whole out of the transmission tunnel for the T56 shifter.
Don't need it for another week or two.
Thanks!
-Ken
Old Feb 6, 2003 | 01:36 PM
silicuda's Avatar
very nice car, what do you need cut exactly? my dad has an iron shop so he has tools.. lemme know...
Old Feb 6, 2003 | 01:58 PM
irocz383's Avatar
Thanks!
I'll use what ever would be best. So far everyone that had done this swap has used a cutting wheel.
They've suggested other methods suck as air-sheers / cutting torch.
I think a cutting wheel will do just fine though.
I'm cutting a hole in the floor board / transmision tunnel. My car was automatic but I'm dropping in a T56 now. Thus I need to cut out the hole so the shifter can come into the cockpit.
Old Feb 6, 2003 | 02:18 PM
Pandamonkey's Avatar
I never would have though so but.........third gens look killer with a SS hood!
Nice ride!!
Old Feb 6, 2003 | 05:23 PM
LuCiFeR97Z28's Avatar
This maybe not be the best idea, but how about renting a precision cutting torch for a day? Kinda like a blow torch but fine tuned to make precise cuts in heavy metal, etc. Good luck Ken.
Old Feb 6, 2003 | 05:25 PM
Rybar's Avatar
Use an air powered cutoff wheel is the easiest. Or use an electric Dremel. It will take longer, but it's easy to use since it is small.
Old Feb 6, 2003 | 06:30 PM
irocz383's Avatar
I have a dremel. I just don't want to spend $30 in bits and to be replacing them every three inches of metal I cut.
I wonder how much an air cutter rents out for.... unless someone has one I can use. An electric one would work just as well wouldn't it?
Old Feb 6, 2003 | 06:41 PM
Rybar's Avatar
Any bodyman or bodyshop should have them.
I'm sure you can rent one, or buy one of those cheap ones from Home Depot for like $40-$50
Old Feb 6, 2003 | 06:42 PM
LT1Z28's Avatar
I did the swap for a buddy of mine i just used a hole saw to start the project then just ripped through the floor like putty with my sawzall. It took me about 5 minutes with a clean cut. If you want to borrow the sawzall let me know. Its the easiest way by far the blade on that thing well mall throught the floor board like no other
Old Feb 6, 2003 | 06:45 PM
irocz383's Avatar
Whats a sawzall?
I guess thats not the same as a hack saw. That would take forever!
I just might have to take you up on that offer Mike! I'll probably be ready to start cutting... hopefully next week!
Old Feb 6, 2003 | 07:03 PM
Rybar's Avatar
NO sh*t i forgot that I did this with my '69 I used a jigsaw with a metal cutting blade. Cut through it in 5 mins. Broke a blade or two but they are cheap.
Old Feb 6, 2003 | 11:57 PM
AlexH's Avatar
That's a sawzall. Some people call them reciprocating saws.
*Lots* of fun.
Old Feb 7, 2003 | 12:00 AM
irocz383's Avatar
Dude! You posted that just after I figured out what it was.
I was actually just going to post something about it being a reciprocating saw!
Thanks though!
fredmr39
Feb 2, 2007 11:25 AM
SSpdRcr
Sep 6, 2005 03:08 PM
Jasonz28camaro
Apr 23, 2004 11:38 AM
